WATER PUMP???
Old Jun 22, 2012 | 10:27 PM
Copedawg's Avatar
Copedawg
WATER PUMP???
06 explorer 4.0 picked up from here: https://www.ford-trucks.com/forums/1...on-issues.html
GRRRRR! Water pump??? Replaced thed the thermostat housing (water outlet) and the glue started to come apart again due to heat.
Water pump is not leaking and there is no slop in the fan (bearings). Could the water pump not be pumping? Could the fins be as small as tick tacks and not be pushing any water? Very late...gonna get an early start again tomorrow. Going to start a new thread and listen for ideas.
Thanks fellas!
Last edited by Copedawg; Jun 22, 2012 at 10:28 PM. Reason: adding: http://www.ford-trucks.com/forums/1170461-06-4-0-overheating-any-common-issues.html
Old Jun 23, 2012 | 09:32 AM
steve(ill)'s Avatar
steve(ill)
flush the radiator and check flow thru the motor and passages.
One Sock
Feb 14, 2012 09:23 AM
grantpage
Sep 27, 2011 03:44 PM
TopNotchCC
Jun 29, 2005 03:04 AM
fordflaresides
Apr 21, 2005 09:46 PM
fordguy101
General Automotive Discussion
Apr 14, 2005 10:40 PM
