Sponsored by: Real Truck
locking the hubs
Old Jun 21, 2012 | 07:00 PM
gunner0828's Avatar
gunner0828
locking the hubs
I have a 08 F350 and I'm not sure if I have to lock the hubs when I put it in 4x4 of does the truck do it automatically?
Old Jun 21, 2012 | 08:05 PM
AGE mechanic's Avatar
AGE mechanic
Probably Auto hubs. Maybe an XL still has manual hubs, I dont know that for sure. Check your manual for further info on operation.
Old Jun 21, 2012 | 08:41 PM
kd0axs's Avatar
kd0axs
Look at the hubs. If they say "AUTO" and "LOCK" they are automatic, if they say "FREE" and "LOCK", you need to lock them manually.
With the automatic hubs, you can still lock them manually if you wish by turning the **** to the LOCK position. This is a nice option to have in case the vacuum lock system fails, because you won't be stuck somewhere without 4WD.
Old Jun 21, 2012 | 09:47 PM
gunner0828's Avatar
gunner0828
awesome! thanks for the help!
Old Jun 22, 2012 | 12:27 AM
biz4two's Avatar
biz4two
Arrow
...also...if you have the ESOF system...you will have a **** on the dash with Auto hubs. If you have the manual lever on the floor, then you'll have manual hubs too.
biz
Old Jun 22, 2012 | 01:49 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
biz
What he said.. If you have a ****, they are auto hubs. If you have a leaver, they are manual.
The auto hubs have a fail safe and can be locked manually if need be. (Ford was smart and not arrogant enough to think that their stuff never fails.)
Also, if you have auto hubs, check their operation before you need them. They tend to develop vacuum leaks.
Old Jun 22, 2012 | 03:09 PM
Tim C's Avatar
Tim C
It's also not a bad idea to manually lock the hubs in once a month or so and drive 5 to 10 miles with the dash switch or lever staying in 2hi of course. That will keep the internal of the hubs and front differential lube and working so there are no surprises if you ever do need them.
g tinsley
Mar 19, 2015 06:28 PM
mongas
Jan 20, 2009 10:57 PM
cpd806
Oct 24, 2005 04:23 PM
George
1978 - 1996 Big Bronco
Jan 2, 2000 10:52 AM
