I did a search but did not find any clear explanations. I have the electronic 4x4 shifter with hubs that state "auto" and "lock". What reason(s) would I ever need to "lock" the hubs? The manual does not even mention why I would need to use the "lock". Thanks.
Lock is used to manually lock the hubs in... it's a backup in case the vacuum-driven system fails. Also, the vacuum hubs require a bit of motion to engage - if you're already stuck, you may not be able to get enough movement to make them lock. Turn the ****, you *know* they're locked in.
o.K. I think I get it but one last stupid question. If I lock the hub do I Still need to turn the 4x4 ****? I am guessing I would need to. Thanks again for the quick replies and answers.
There is a small arrow where you line up the LOCK and AUTO selection. It has to be set in one or the other and can only turn in one direction from one to the other (flip back and fourth)
The manual locking hubs are there because Ford knew that the electronic locks would fail. Mine has and just about everyone I know with a 03+ 4wd has at one point or another. The good news is they do a pretty good job of fixing it when it happens. Still love my truck! 04 250 cc lariat fx4 6.0
My brother and I each had '96 F-150s with ESOF. Both of us were replacing the hubs all the time. They worked, but the engaging dogs would break off (quite fragile). We both installed manual hubs and never had a problem since. Sure you have to turn the little **** but at least you know it will work when you need it.
Niether of us had any problem with the transfer case shifting properly.
The system works just like the manual sytem. If you get stuck in 2wd and cannot move, turn the switch on the dash. This will engage the transfer case and the hubs. The front wheels do not need to turn in order for the axles/hubs to lock. All that has to happen is for the splines on the axles to orient themselves to line up with the splines on the hubs.
Manual or auto it's hot good for the hubs to engage under A load.
No. it's not. But, engaging them doesn't require the vehicle to be in motion either, just revolutions of either the axles or the hubs. If the vehicle is stranded, then the axles have to do the job of mating with the hubs.
If you get in a bind in 2wd and need to lock the hubs, just remember to give them time to engage - like rocking back and forth a little > with a manual this requires just easing off the clutch > with an auto just easing on the gas pedal.
