Cruise Control Quit Working
Old Jun 20, 2012 | 10:58 AM
arkie3's Avatar
arkie3
Took off on a trip yesterday and after I got through town decided to set cruise control. Did so, let off the pedal and slowed down. Tried again a couple of times, until my daughter chastised me for playing around. I informed her I was not playing around, that the cruise wasn't engaging. Turned it off and back on, same situation. Drove until I turned onto a secondary road and pulled over and killed the ignition and restarted. Everything back to normal. Anyone else experienced this?
Old Jun 20, 2012 | 11:23 AM
biz4two's Avatar
biz4two
Arrow
Interesting! Hmmm...when you turned on the cruise control...did the image turn on within the dash? It should have been an orange/amber color. Then when you hit 'set'...it should turn green.
This is the first...I've heard of this issue.
biz
Old Jun 20, 2012 | 12:04 PM
Byram's Avatar
Byram
A while back I accidentally clicked resume after stopping at a highway light. I think that I was maybe right below the minimum cruise speed (45mph?) - anyway it wouldn't take - worked just like you describe - turned off - then on several times. Also - I got the small info screen - not the productivity screen and had some sort of amber CEL type light. Watching everything - Temps , lights etc. nothing else seem to be a problem. 30 minutes later I turned truck off - ate lunch - then turned it back on - Light had cleared - cruise worked as normal - that was a year and a half ago - no problem since..
could the speed have been what happened to you?
Old Jun 20, 2012 | 11:00 PM
arkie3's Avatar
arkie3
The info screen remained normal. The amber light turned green, but the system didn't regulate. The light went off and on as I turned cruise off and on. I didn't set the cruise until I was through town and at 60 mph. Rather strange.
Old Jun 21, 2012 | 11:12 AM
smallcandle's Avatar
smallcandle
I've had this exact scenario happen to me twice in the past 6 months. Both times I have pulled over, shut the truck down, restarted and the cruise works again. Interesting to see someone else experiencing the same thing...
Old Jan 15, 2020 | 04:46 PM
castellscl's Avatar
castellscl
Exactly the same thing, anyone ever find the issue?
Old Jan 15, 2020 | 06:54 PM
747Driver's Avatar
747Driver
I'm having the same issue on my 2018. Usually have the message at startup though that the front collision avoidance isn't active. When I have that at start up, the cruise won't work. If shut down and then restart, usually resets it and then cruise will work.
octaneforce
Nov 19, 2009 07:57 PM
Big Sky
Jul 22, 2007 10:04 PM
gdogf150
1997 - 2003 F150
Jun 2, 2003 11:29 PM
TwoF150
May 4, 2003 01:25 AM
