I've read almost every post I can find about the issue and I think I understand the pros/cons.
Since I do not do any heavy towing, only a 30' toy hauler I believe electric fans will work for me. I'm looking for the extra power along with better fuel mileage.
Does anyone make a kit for the 2003 6.0 with electric fan clutch? Thoughts please...
When I bought my truck the electric wires had all been caught by the fan, so I put an OEM on myself and it ran non stop for several days, then after some squeling noise which sounded like a metal clutch slipping the fan operated normally for only a couple of days. Now I'm getting code PO528 and PO480. I was able to clear with my CTS but they came back and the fan is not coming on at all.
Only a 30' Toy hauler??? I would consider that heavy towing for the truck in your sig. Especially if you are putting any toys in it.
I am not a big fan of the electric.
An electric fan will not give you more power, or better fuel mileage.
When are people going to realize that the fan clutch on the 6.0L is computer controlled. When the computer commands it to 0%, any drag on the engine is due to nothing more than a little friction in the clutch and is probably not measurable.
The electric fan costs you a bunch of money in parts and engineering, gains you absolutely nothing, and may cost you an overheated and potentially damaged engine.
I have to say that I also am not a fan of the electric fans. They have not performed well for me in several applications and I went back to mechanical fans every time. I have to agree with all of the above statements.
I also have the Edge CTS and I do get the P0528 a few times a month. The more I play the more it comes on. As far as I can tell though, the fan is working so I just let it be.
That's the information I was looking for and I really appreciate the input.
I guess I installed a defective fan clutch. Like I stated in my original post when I first installed the fan stayed on 100% all the time for several days then it appeared to start working correctly. When the temp reached 210 it engauged and drop the temp to 190ish. But that only lasted a couple of days now the temp will reach 225 and 227 a couple of times and the fan doesn't seem to be kicking in. I'll request another part and see if I just got a lemon.
Check the wiring carefully also. Sometimes the harness will fail.
alright I gotta a little problem but its prob simple and maybe im over thinking it. But my fan is stuck on it happened when I was heading south on I-5 when it was about 95- 100 degrees out. I manually turned the fan with my key off there is a little resistance but will spin so I dont think its my clutch i pulled the plug for the fan and started the truck and the dam thing stayed on!? is there a test for the fan clutch or is it just the clutch and I dont realize it?
If you unplugged the electrical connection to the clutch fan and it stays fully engaged then you need a new clutch.
I would also point out that I haven't seen anyone offering a fan this big, with this kind of blade pitch, controlled by the PCM, and capable of turning 4,000rpm. Look at this pic for a minute, you don't notice leaning over the fender so much but when you see it like this..it almost spans the frame rails. This thing is ginormous!
4000k rpm is engine speed. the water pump pully is smaller then the crank pully.
i have active commanded a fan befor and had a belt snap. it was kind of funny really
Cheezit did it look like a squirrel nest after is went snap?
I would also like to point out that you going to be really searching
hard high and low to find an electric fan that can put out the same CFM
for the size that will fit into this space.
That is a GREAT picture - sort of looks like a jet engine turbine...
