Core support bushings?
Old Jun 15, 2012 | 12:56 PM
hickory1991's Avatar
hickory1991
How many ft/lbs of torque do you tighten core support bushings and cab bushings?
Old Jun 15, 2012 | 02:24 PM
crazy96863's Avatar
crazy96863
Not the best answer here but i did mine just until it felt right... Look for just enough squish of the rubber. Considering the condition of your rubber and the threads, a torque could really be subjective anyway. There is always threadlocker if it makes you feel better; or a jam nut which might be better.
Old Jun 15, 2012 | 03:32 PM
mark a.'s Avatar
mark a.
Just until you see the rubber starting to squeeze out some.
Old Jun 15, 2012 | 05:21 PM
HIO Silver's Avatar
HIO Silver
When tightening, the bulge should be no more that the diameter of the washer or the mount that it is resting on.
2x on using Loc-tite for peace of mind.
Old Jun 15, 2012 | 06:05 PM
bamaf150's Avatar
bamaf150
Its been awhile since I replaced mine but if I'm not mistaken, wont the two halves of the mounting hardware interlock with each other, preventing overtightening? IIRC I tightened mine down until they were really snug and wouldnt turn anymore without an extension and there is little to no squish, the top and bottom pieces are cone shaped and interlock with each other when tight?
Old Jun 15, 2012 | 07:16 PM
crazy96863's Avatar
crazy96863
I think bama might be right but its still good to keep an eye on what your doing.
Old Jun 15, 2012 | 10:35 PM
Stinky7-11's Avatar
Stinky7-11
That's exactly how I did mine with the same results, I used all new hardware also
Old Jun 16, 2012 | 07:38 AM
hickory1991
Thanks for all the replies. Always good to know help is just a click or two away.
cbrcassio
13
Feb 27, 2014 08:20 AM
96ford250
Jan 18, 2013 05:49 PM
JB78f150
Mar 20, 2012 12:50 PM
stangtruck87
Apr 16, 2011 10:13 PM
kd123
May 10, 2006 08:25 AM
