Sponsored by: Auxito
windsield wiper phatom operation
Old Jun 14, 2012 | 08:34 PM
schmitty99's Avatar
schmitty99
Have a 2000 f150 xlt 4x4 that has windsield wipers intermitenly comes on for no reason .For only at the most four swipes,then stays off. some times it seems that it happens after ive used the turn signal.anyone had this annoying problem?
Old Jun 15, 2012 | 05:20 AM
projectSHO89's Avatar
projectSHO89
Bad MFS...
Old Jun 15, 2012 | 10:24 PM
schmitty99's Avatar
schmitty99
How tuff is the repair to do?
Old Jun 15, 2012 | 11:15 PM
LxMan1's Avatar
LxMan1
Just remove the plastic covers over the steering column and it is right there.
Old Jun 21, 2012 | 06:35 PM
schmitty99's Avatar
schmitty99
cool thanks
Old Aug 8, 2012 | 07:04 PM
schmitty99's Avatar
schmitty99
Not MFS switch
just wanted to reply to my own post ,i did pull out the MFS (turn sig switch) and noticed losts of grease with a build up of copper from the contacts mixed in w/the grease.in my mind there was a possibilty of that muck shorting out or the grease becoming a conductor,so all i did was clean with some contact cleaner and re-grease and have not had a single incident with fatom signal operation. glad i dint purchase the MFS ,maybe some r bad but not the case w/ mine.
Old Aug 8, 2012 | 09:30 PM
Club Wagon's Avatar
Club Wagon
Had different kind of "windsield wiper phatom operation". Mine frequently lost intermittent speeds & hi/lo positions turned into 1 intermittent setting & 1 continuous speed. Suspected the 'black box' behind knee panel, but 1 look at its miserable location had me saying Kaa-rist! Was unable to find used 1 at U-Pull, however discovered that by inspecting the plug/wiring to this box, I'd jostled things enough to drive out the gremlin! Presume a loose ground.
Old Aug 15, 2012 | 05:49 AM
jbtecnico1's Avatar
jbtecnico1
'97 F150, 4x4, 66k miles, same problem with windshield wipers and turn signals...replaced MFS with after market for ~$80... Good as new...easy job.
Old Aug 15, 2012 | 09:28 PM
biscuit141's Avatar
biscuit141
How did you open it up to find the dirty contacts? I need to do this to my switch soon.
70torino429
Sep 8, 2011 04:03 PM
MCISPARKY
Sep 25, 2003 07:55 PM
roamer117
Apr 2, 2003 07:48 AM
jroyalty
Jul 24, 2002 03:57 PM
