What Size Spring Lock Tool Do I Need?
Old Jun 14, 2012 | 03:42 PM
tperk100's Avatar
tperk100
2004 Ford F350 Diesel
I cannot get the spring lock at the orifice to disconnect. I have the red, white, blue, black plastic 4 tool set AND I have a metal pivoting tool. Both tools/sets offer the same sizes...3/8, 1/2, 5/8, 3/4.
The 5/8 is too big and the 1/2 is too small! The 5/8 (black) has a lot of slope when trying to use it, and I can see where the flange is too large in circumference to engage the spring. The 1/2 is too small and will not mate up flush with the radius of the line. I have previously "forced " the 5/8 (black) to work, but I can't even get that to happen now.
Can someone tell either what I am doing wrong or what the correct size tool is, and where I can get one?
Thanks much!
Old Jun 15, 2012 | 07:14 AM
projectSHO89's Avatar
projectSHO89
Are you certain you aren't putting the tool on the wrong side of the spring fitting? Remember, it has to slip under the spring so as to expand it.
Use an inspection mirror and flashlight to verify orientation.
Old Jun 15, 2012 | 09:22 AM
tperk100's Avatar
tperk100
Orientation is correct. I need to know what size tool to use.
Old Jun 17, 2012 | 10:23 PM
lsrx101's Avatar
lsrx101
You need the Blue one. That's the one for a #8 line on the garter spring side (Evaporator side) of the connection.
Which style of tool are you using? I've found that the spring loaded "clamshell" type usually work better than others in most applications. They cost a little more, though.
Old Jun 18, 2012 | 12:08 AM
tperk100's Avatar
tperk100
Yes...I am a dumb*** It is the blue one. Thanks
smithdakota
Aug 13, 2016 09:01 PM
Tiler
May 7, 2013 09:24 PM
MrRogers
Aug 1, 2012 02:30 PM
ranger1999 Bob
General Automotive Discussion
Aug 30, 2008 07:23 PM
woodallap
Sep 28, 2006 10:37 PM
