Missaligned Motor Mount
Old Jun 13, 2012 | 09:44 PM
cactusbronco's Avatar
cactusbronco
Guys, I am having a heck of a time replacing the right motor mount in my truck. I removed the 2 bolts and nut and jacked the motor up with my floor jack and a block of wood under the oil pan. All went smoothly when the mount cleared the frame and I removed it. The trouble started when I noticed the holes in the block don't line up with the holes in the new mount. I took it out and compared it with the old one and they are the same. What am I doing wrong? Do I have to get a cherry picker and lift the engine from the top or is it possible to lever it? Thanks in advance!
Old Jun 14, 2012 | 04:31 AM
CountryBumkin's Avatar
CountryBumkin
Are you bolting the mount to the block then lowering engine onto perch - or are you bolting it to the perch first then trying to bolt it to the block. First method is prefered (necessary I think).
Old Jun 14, 2012 | 07:07 AM
Gary Lewis's Avatar
Gary Lewis
X2. The slot on the perch is tapered at the top, which causes the stud to align as the weight of the engine forces it down into the slot.
But, if that doesn't work you might loosen the nut on the left side mount where it bolts to the perch and let both sides adjust. But, don't go wild with the jack as the engine can move quite a bit with both mounts loose.
Old Jun 14, 2012 | 08:23 PM
cactusbronco
Thanks Guys! I looked at it again after reading your replies and had the duh! moment. Did it the way you said and voila! It's in and no more clunking!
Old Jun 14, 2012 | 08:33 PM
Gary Lewis's Avatar
Gary Lewis
Good deal! Thanks for letting us know.
WA429
Sep 20, 2012 07:20 AM
73 ford guy
Jan 4, 2009 06:37 PM
n8mojo
Sep 14, 2005 06:30 PM
cmoore
Jun 9, 2004 09:05 PM
house
1978 - 1996 Big Bronco
Apr 27, 2003 02:23 AM
