Rear spring parts---Help!
Old 06-13-2012, 05:00 PM
TheRedPheonix's Avatar
TheRedPheonix
TheRedPheonix is offline
Ok, in the process of fixing up the red truck I need to replace the spring mount brackets on the front of the rear springs, the shackles at the rear, and the bushings for it all. That was all well and good except I have 2 1/4 inch springs! So where can I find these parts without paying an arm and a leg? And a cheap(er) set of body mounts? Thanks!
Old 06-13-2012, 06:57 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
armstrongfordtrucks is offline
Check your local spring shops, they used the same springs up til 1997 in the F-350 dual wheel.
Old 06-13-2012, 08:12 PM
TheRedPheonix
The local shop was unable to locate the parts for me, and I was looking for something better than stock. They basically gave up because the truck is "too old".
Old 06-13-2012, 08:40 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Well that's pretty lame of that shop to send you packing. They didn't even try. I'd be leery of sending that place any future business (unless you're caught btwn a rock and a hard place).
Nonetheless, I found a site in less than five seconds with 2.25-inch wide hangers: M963 Spring Hanger F250-F350 2.25''Spring
$37.37 each. Upgrade them by welding on backplates and gussets.
Leaf spring shackles? Make'em yourself with 1/4-inch plate. Easier with a plasma cutter or torch. Alternatively, visit Ballistic Fabrication.
Old 06-13-2012, 09:45 PM
hasteranger's Avatar
hasteranger
hasteranger is offline
some people have had bad luck with ballistic.. idk. I guess they have changed for the better but still iffy IMO. Ruff stuff sells shackles too and they have pretty decent customer service.
Old 06-14-2012, 11:07 AM
TheRedPheonix
They are good with springs and trailers, but don't have much of a cross reference for older stuff. I did find those brackets, but my truck doesn't need those, it needs the other ones for the front end of the spring.
Old 06-15-2012, 01:24 PM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
Get the 2.5" spring hangers off of a 70's truck or 80's-90's 2wd. You can then run a .125" spacer on either side of the leaf in the hanger to make up for the narrower springs. The 2.5" wide stuff is everywhere.
Stuff for 3" springs is a little trickier, but the 80's-90's 4wd F-series and broncos had them so they aren't that bad to find either.
Old 06-16-2012, 12:05 PM
TheRedPheonix
Thanks, I'll keep and eye out for those. I was able to find all the bushings I need on amazon.
Old 06-16-2012, 12:33 PM
hasteranger
there are a lot of 70's and 80's 2wd's in the junkyard here, let me know if you can't find them I may be able to pull a set for you for a pretty reasonable price.
Old 06-25-2012, 06:13 PM
ChaseTruck754
Care to find me some Silverado leaf hangers & trade for the highboy ones?
I'd have to re-confirm but I'm pretty sure the leafs coming off the back of the truck were 2.25" wide...
68murc
05-23-2014 07:49 PM
JethroF250
13
03-31-2009 02:36 PM
TheCyanMonster
07-12-2008 07:44 AM
venom_99
05-06-2006 08:01 AM
mauicruza
1966 - 1977 Early Broncos
09-07-2005 12:37 PM
Quick Reply: Rear spring parts---Help!
