Sponsored by: Real Truck
F250 A/C Question
Old Jun 13, 2012 | 11:04 AM
topcopsr's Avatar
topcopsr
F250 A/C Question
Have a question about my 2003 F250 SD 5.4L. I hear a load sound coming from the a/c Compressor at start-up that lasts about 1 second. This sound gives you the first impression that the clutch is bad or something. Now the details are. This only happens after you have been running the a/c on hot days and then shut the truck off. If you start it up within the next 5 minutes you here it. It never happens on cold starts, and if you turn the a/c off you dont here it. If you let the truck sit like 15 minutes or so you do not here it either. You never here it in the winter even when its on defrost. The first thing I did is replace the Clutch thinking it was going. That didnt work. Still the same noise. So what i was thinking is it seems at shutoff is it building pressure and not being released in time and when I go to start there is alot of pressure in the system? Could this be due to pressure in system or a pressure switch. Any suggestions would help.
Thanks
Old Jun 22, 2012 | 11:27 PM
topcopsr's Avatar
topcopsr
A/C
Thanks
Any help here????
R.J.M.
16
Oct 2, 2011 08:50 PM
Virto
Oct 5, 2009 11:06 AM
kinglouie63
1997 - 2003 F150
Jun 29, 2006 05:48 PM
Jet Lizard
Jan 3, 2005 06:32 PM
mcb3211
Jul 21, 2003 11:25 AM
