Sponsored by: Auxito
Tire question
Old Jun 12, 2012 | 09:00 PM
Palomino's Avatar
Palomino
Tire question
I used to have a 1997 f150 that had p235/70r16 size tires. I now have a 2000 f150 that I bought with low miles, but it has p255/70r16 tires. The 2000 f150 needs new tires and I am wondering if I need the p255 size tires because I looked it up and the p235 size tires were an option on the 2000 f150. What is involved in changing tires sizes or is it a bad idea to do so? I imagine the computer needs to be reprogrammed? What about the speedometer?
The label on the drivers door on the 2000 f150 does say p255 size tires...
Thanks,
<Mike
Old Jun 12, 2012 | 09:37 PM
Bluegrass 7's Avatar
Bluegrass 7
Put them on and enjoy.
The speedo is and will be off a bit but you can see that the next time you run by a road side speed monitor and then know what correction to apply to the speed indication.
My truck is stock and 2 to 3 mph high reading and it has the stock size tires.
Good luck.
Old Jun 12, 2012 | 09:47 PM
Palomino's Avatar
Palomino
So I take it there is no easy way to reset or calibrate the speedo for the new size?
Old Jun 13, 2012 | 01:13 AM
Bluegrass 7
You would have to get into the program and change the data word bits to do any corrections.
If a dealer will do that, your good to go.
If you have mechanical drive, the speedo gear would be the changed.
Old Jun 13, 2012 | 06:53 AM
critterf1's Avatar
critterf1
It will look goofy as ***** with those little tires.
Old Jun 13, 2012 | 01:36 PM
00GT's Avatar
00GT
I agree...
Just put on what it came with and call it a day. Then you don't have mess with anything.
WJC
Mar 16, 2009 11:59 AM
DaveK88
Aug 28, 2006 07:58 PM
LTTLMAN
Apr 15, 2005 07:39 AM
PEHall
Nov 14, 2001 12:46 PM
Larry619
Sep 24, 2000 07:59 PM
