New Some help with gauges
Old Jun 11, 2012 | 10:32 PM
westtex's Avatar
westtex
Hi I'm new here just bought a 1965 f100 custom cab with 4 instrument gauges and I'm having a little trouble getting my gauges to work. I have replaced the voltage regulator and the sending units. the gauges will work if they are plugged in individually. If the fuel, temp, and oil pressure are all plugged in they wont move at all and if 2 of them are plugged in they only move about a quarter way up. Really frustrated help would be appreciated.
Old Jun 12, 2012 | 07:18 PM
rustywheel68's Avatar
rustywheel68
welcome aboard.
did you replace the voltage regulator in the engine compartment, or the one under the dash?
if it was the one in the engine compartment, do a search here for "instrument cluster voltage regulator". you may want to verify that all is well behind the dash.
Old Jun 14, 2012 | 05:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
B9MZ-10804-C .. ICVR ~ Instrument Cluster Voltage Regulator (Motorcraft GR-508) / Bolts to backside of instrument cluster.
Misc applications: 1957/66 F100/1100 / 1965/66 Mustang / 1966/77 Bronco.
1957/91: There are TEN different types of ICVR's, take the original with you to the parts store to match it up.
westtex: Do you have an oil gauge or an oil idiot (warning) lamp?
The ICVR is the same for both, but the oil sending unit is specific to either gauges or idiot lamps.
Old Jun 14, 2012 | 01:13 PM
westtex's Avatar
westtex
I replaced the one under the dash, and i have the oil warning lamp and a gauge.
Old Jun 14, 2012 | 02:21 PM
daveengelson's Avatar
daveengelson
The instrument cluster in my CC is of the 'sweeping' variety and the the instruments would occasionally fluctuate, I attached a ground wire from the instrument cluster to the steering column bracket and the instruments seem to have settled down. The 65's are not garaged so I cleaned all the ground connections and added a tab bit of dielectric grease to them, as well as, the harness connectors.
Suggest test CVR, it should oscillate between 0-10v. There's also a way to test guages using a 2 'D' cell flashlight, disconnect power and attach a wire from each side of gauge to the the neg. and pos. side of flashlight, the 3v should peak the needle.
Old Jun 14, 2012 | 06:39 PM
NumberDummy
When both the optional oil pressure gauge and warning lamp are present, there's a fitting with provisions for the two oil sending units, one for the warning lamp, one for the oil pressure guage.
Did you replace both sending units?
Old Jun 18, 2012 | 01:55 PM
camperspecial65's Avatar
camperspecial65
Also, the larger can oil pressure gauge sending unit is engine specific...there is a number stamped in the square base of them which ID's them..Bill, myself or others with the master parts catalogs can ID which one you have...the smaller one for the blade connector AFAIK wasnt marked for the specific engine. I do have a few of the larger sending units...if needed.
- cs65
Old Jun 18, 2012 | 03:49 PM
NumberDummy
Since when? The same puppy was used in myriad 1957/97 I-6 & V8's.
E4ZZ-9278-A (replaced C9ZZ-9278-A, C7ZZ-9278-A & B7T-9278-A) .. Oil Pressure Gauge Sending Unit (Motorcraft SW-1547-B) / Available from Ford
MSRP: $34.26 / FTE sponsor tousleyfordparts.com price: $18.84 / FTE sponsor horizonpartsguy.com price: $20.56.
Tousley Ford = White Bear Lake MN / horizonpartsguy.com (formerly partsguyed.com) = Horizon Ford Truck Center in Seattle (Tukwila) WA
BEN WHEELAN
Feb 26, 2018 11:29 AM
mountain dewd
Jan 10, 2018 01:48 PM
1972RedNeck
Mar 22, 2015 12:07 PM
SwampyBull
Nov 1, 2012 09:14 AM
ken selvy
13
Jan 14, 2010 11:35 PM
