multi position switch
Old Jun 11, 2012 | 09:24 PM
1nascar24fan's Avatar
1nascar24fan
Question multi position switch
  • Hey all,got an electrical problem and need a little guidance.First the symptoms.
  • Sometimes headlights dont come on.
  • The chime dings with key in ignition and doors closed.
  • The door ajar light stays on when driving when doors are closed.
  • The domelight stays on when door ajar light is on.
  • The auto locks will sometimes work after driving a while.
I,ve searched this but got a lot of info for each one but not all together. Any help would be greatly appreciated.
Old Jun 11, 2012 | 09:26 PM
BigAlsPSD's Avatar
BigAlsPSD
I would start by spraying some WD40 or like, on the actuator for the doors, to eliminate most of the issues, maybe all of them. Could be VSM related though.
Old Jun 11, 2012 | 09:32 PM
ToMang07's Avatar
ToMang07
^Agree with the above.
Also, check under the dash for any signs of water.
Old Jun 11, 2012 | 11:26 PM
GonzoCSU's Avatar
GonzoCSU
You can use a Phillips screw driver to latch and unlatch the door while spraying it (I do this when I want the radio on and the door open without hearing the annoying dinging). Should fix all your problems except maybe the headlights.
RAMPAGE_F350
41
Oct 10, 2014 01:43 PM
tmitchell5188
Jul 29, 2008 09:03 PM
3KIDDAD
Jan 23, 2007 07:38 PM
trakman
Apr 25, 2005 11:54 AM
rrs
Feb 4, 2004 12:32 PM
