I would start by spraying some WD40 or like, on the actuator for the doors, to eliminate most of the issues, maybe all of them. Could be VSM related though.
You can use a Phillips screw driver to latch and unlatch the door while spraying it (I do this when I want the radio on and the door open without hearing the annoying dinging). Should fix all your problems except maybe the headlights.
