gettin hot
Old Jun 14, 2012 | 06:39 PM
jimwilsonmasonry's Avatar
jimwilsonmasonry
Ok i put a Ford tstat in it and no change it still gets hot could something be blocked off in my engine or maybe what seems like a good water pump is bad but i really think there is something blocked in the oil cooler or the block how could I fix this
Old Jun 14, 2012 | 06:47 PM
BuckHammer's Avatar
BuckHammer
Originally Posted by jimwilsonmasonry
...how could I fix this
Like this:
Okay, I put a Ford thermostat in it and there are no changes. It still gets hot. Could something be blocked off in my engine? Maybe what seems like a good water pump is bad, but I really think there is something that is blocked in the oil cooler or the block. How could I fix this?
Old Jun 14, 2012 | 06:55 PM
BuckHammer's Avatar
BuckHammer
Seriously, though, was your truck overheating before the new thermostat?
Old Jun 14, 2012 | 06:56 PM
ReBilld's Avatar
ReBilld
Could it be a bad coolant temp sensor or faulty gauge?
Old Jun 14, 2012 | 07:02 PM
BuckHammer's Avatar
BuckHammer
...my thermostat is the long stem but it still doesn't touch that part on the water pump that should touch the thermostat...
I don't know what you mean here.
For reference, here is a picture of my old thermostat and water pump combination and my new thermostat and water pump combination.
Old Jun 14, 2012 | 09:23 PM
oldbird1965's Avatar
oldbird1965
I would have to go back and read it again but I believe he said he could hear it boiling.
Old Jun 14, 2012 | 10:23 PM
ReBilld's Avatar
ReBilld
Ahhh, I guess I missed that.
Old Jun 15, 2012 | 11:28 AM
Cratos's Avatar
Cratos
might be time to have your rad rotted mine had 6 inch os crud in the bottom when I had it done. well worth it.
Old Jun 15, 2012 | 11:54 AM
BuckHammer's Avatar
BuckHammer
Has anyone been able to tell if the OP's issue started before or after his initial thermostat replacement? Inductive reasoning would suggest that he probably replaced the thermostat in an attempt to cure the overheating issue, but I can't find where it says one way or the other. It's sort of important with troubleshooting this to know.
See, if it was going on before he replaced the thermostat, then he's effectively eliminated the thermostat as a possible cause of the problem. However, if he replaced the thermostat and the issue arose only after the replacement, that would suggest that the thermostat is the cause here.
Old Jun 15, 2012 | 11:55 AM
DarkStarMedia's Avatar
DarkStarMedia
Originally Posted by Usaman
My needle has never passed the "N" of Normal under any circumstance of towing and plowing. I would suggest replacing the Tstat AND the overfill cap with a new one fron AutoZone as it could be losing its pressurization and lowering the boiling point.
Same here... the hottest I have ever seen it, even with 110+ ambient and AC going full blast, was the very first part of the N in normal.
Richard
EDT: note that I run empty most of the time... sometimes some steel in the bed...
Old Jun 17, 2012 | 12:28 AM
FARM69's Avatar
FARM69
I wonder what the condition of the OP's radiator is? Maybe it needs to be washed and combed out?
I've had mine pretty hot before towing... I've never heard of a PSD boiling the water before.
Old Jun 17, 2012 | 10:25 PM
jimwilsonmasonry
Ok my radiator seems to flow very well but my water pump doesn't seem to be pumping very much water I am pretty sure that is my problem now at least I'm hoping it is and that's why if I drive it nice and slow and don't go over 50 mph it won't get that hot but if i drive hard at all or 70 on the interstate it gets very hot could that be my issue
Old Jun 17, 2012 | 10:29 PM
  #28
fordman67's Avatar
fordman67
So no boost it is ok.does it loose any water either way...
Old Jun 19, 2012 | 12:36 AM
  #29
jimwilsonmasonry
Yea it seems to be leaking from the oil cooler and i just replaced the gaskets and o rings on that a couple years ago
Jeremy Garren
Jul 4, 2018 04:38 PM
Eallend7
Feb 25, 2013 05:58 AM
plgebbia
Nov 13, 2010 05:32 PM
keisha9
3.8 & 4.2L V6
Jun 12, 2007 07:58 AM
horsecop
Mar 24, 2004 07:31 AM
