1978 - 1996 Big Bronco
Larger throttle body
Old May 6, 2003 | 08:11 PM
drittler's Avatar
drittler
I hear there's a way to "custom" fabricate the K&N FIPK system? Is it worth it or should I find a larger throttle body and hoses?
Where do I find a throttle body and what size am I looking for?
Thanks
Old May 6, 2003 | 08:20 PM
WhëëlMå1's Avatar
WhëëlMå1
http://performanceunlimited.com/projectmpg/ That should give you some insight on the whole FIPK dillema. As for a bigger throttle body, you want more power? Realize that with a bigger throttle body, you will also consume more gas.
Rich
Old May 16, 2003 | 12:58 PM
Wakeboarder141's Avatar
Wakeboarder141
I know a few people who have just taken an open K&N Filter and some PVC pipe and made their own FIPK. You just have to find something to mount it to so it isn;t bouncing around. It sounds pretty cool, but from that Project MPG page it sounds like it may not be the best solution.
Old May 16, 2003 | 03:20 PM
Lookinfurfun's Avatar
Lookinfurfun
You can do a search for homeade FIPK. Somebody around here made one.
When you click on the link to project MPG they show the larger throttle body that they used on the 460 motor.
This was the quote for its effectiveness "After testing with this upgrade Mileage was not affected, however, The absence of water needed to run through the throttle body (like OEM) also decreased the octane requirement of the fuel therefore dramatically reducing fuel cost per mile in that sense... saving the equivalent of 6% fuel savings per mile. Power was significantly increased by 22 hp and 31 ft lbs of toque and the throttle response was very notably improved"
I don't know if you would have the same or similar results with a 302 or 351.
Old May 16, 2003 | 04:33 PM
greystreak92's Avatar
greystreak92
If you opt for the throttle body, Edelbrock/BBK is the only one I know of. There are two sizes: twin 56mm and twin 61mm. The twin 61mm requires port matching to the upper intake plenum. About $320 at proficient performance for the twin 56mm. Not sure on the 61mm.
Old May 17, 2003 | 09:46 AM
msautry's Avatar
msautry
I made one of my own using stock parts - there's a picture of it and a description of it in my gallery.
I've got a couple of ideas re: relocating it for more cold air, etc.
Mileage - don't think it really helped. Throttle response seems a little better, but that might just be the way it sounds when you nail it
just my 2 cents....
msautry
Old May 19, 2003 | 01:25 AM
brian_06328's Avatar
brian_06328
I read somewhere that going to a larger bore throttle body will decrease your low end torque
Old May 19, 2003 | 01:37 AM
greystreak92
Just a humble opinion but, I would think that as long as the intake and exhaust systems could handle close to the same amount of air flow through them, you should see an increase in power across the entire rpm range. The "power band" is determined more by the cam setup is it not? "When" the valves open and close and "how long" they stay that way during the cycle does more for "where" the torque gains are seen.
Now, pulling more air through the system will require greater amounts of fuel to keep the mixture optimal as I understand it.
Old May 19, 2003 | 03:40 AM
brian_06328
Like I said, it was something I read. Wish I could remember where.
It was most likely referring to changing to a larger throttle body without other upgrades, but without rereading it I'm just guessing.
Brian
Old May 19, 2003 | 11:45 PM
greystreak92
Now thats a possibility. Altering one part of the intake system and not the rest could cause some oddities in performance I would think.
zman764
Modular V8 (4.6L, 5.4L)
Mar 26, 2006 09:25 PM
travlnman
3.8 & 4.2L V6
25
Dec 5, 2003 07:27 PM
nafzimo
Modular V10 (6.8l)
45
Jun 28, 2003 03:39 AM
serialbowl00
1983 - 2012 Ranger & B-Series
Jun 14, 2003 08:57 PM
