wiring harnesses
Old Jun 11, 2012 | 07:01 PM
electricguru's Avatar
electricguru
wiring harnesses
I was wondering if anyone had some master list made with all the different wiring harnesses (mine is specifically a 73 f100). I'd like to replace a lot of the old plugs. From what I find, all the numbering is wacky.
Old Jun 11, 2012 | 07:09 PM
mikeo0o0o0's Avatar
mikeo0o0o0
There is no "master list" for wiring harnesses. I'm also restoring a '73 F100 and was able to locate all harnesses except the main underdash harness and the frame harness that runs from front to rear.
There can be several different harnesses for the same application depending on options, wheelbase, gauges/idiot lights, 2WD, 4WD etc.
Let me know what you need, I'll look up the p/n and do a search.
Old Jun 11, 2012 | 07:17 PM
electricguru
Well, i knew they didn't make one of such, but i figured with so many builds that have gone on, maybe i'd luck up on someone that has put one together himself... i have:
390
LWB
C6
2WD
Factory A/C
everything is stock...
i specifically wanted to replace the rear wiring near the tailgate for license plate lighting, and probably brakes as well. mine has been spliced to high heaven... i also need to remedy this weird fade in and out with my whole system as i increase rpms... i figure it was easier and cleaner to just replace all that old stuff, hence why i wanted a list of as many as possible... thanks for the help!
Old Jun 11, 2012 | 08:01 PM
lafermedavid's Avatar
lafermedavid
wiring harness
Hey Mike I contacted the place in Road Island,they told me they didnot work on vehicles{trucks} that are as new as our dents,maybe in another 20 years thanks Mike
Old Jun 12, 2012 | 07:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
390
LWB
C6
2WD
Factory A/C
There are four different pieces that you need to replace the rear tail light wiring.
Wiring assy., rear lamp connecting
D3TZ-13A409-D
RH Lamp assy.
D3TZ-13404-A
LH Lamp assy.
D3TZ-13405-A
Side marker wiring assy. (you'll need two)
D3TZ-15A442-C
Wesley Obsolete Parts, Liberty, KY has all the items (606) 787-5293
Green Sales, Cincinnati, OH has everything EXCEPT 13A409 (800) 543-4959
Haven Ford, Haven, KS has the two tail light assy's. (620) 465-2252
Other dealer suppliers have one or two of the pieces, let me know if you need more names. On the '73 the rear tail light assy's contain part of the wiring harness. They plug directly into the 13A409 harness assy.
Old Jun 12, 2012 | 10:39 PM
mikeo0o0o0's Avatar
mikeo0o0o0
OOPS! IIRC I told you Rhode Island Wiring....close but not right. The one I was thinking of was Narragansett Reproductions.
They're both in Rhode Island and I believe they are owned by two brothers.
Narragansett Reproductions - Wiring Harnesses and antique car / automobile restoration supplies
Old Jun 22, 2012 | 09:14 PM
electricguru
nice... i'll check these out...
moreford
Dec 8, 2014 11:32 AM
81F100C
Jul 20, 2012 06:55 PM
mikeo0o0o0
WTB - Parts & other
May 4, 2010 09:36 PM
Take2
Nov 15, 2006 06:24 AM
sarah
15
Feb 22, 2001 05:59 PM
