Heli Coil question
Old Jun 11, 2012 | 05:37 PM
JRS2's Avatar
JRS2
Heli Coil question
Ok guys this weekend working on a motorcycle in addition to the truck. The question is - does it make any difference in the insert brands from one manufacturer to another ? Had one supplier that sells metric only say no, but I certainly do not want any problems ..... Heli coil is the brand for this particular size and pitch that I am using ....
Thks
Old Jun 11, 2012 | 06:59 PM
critterf1's Avatar
critterf1
Have never noticed any difference in brands.
Old Jun 12, 2012 | 04:53 AM
EPNCSU2006's Avatar
EPNCSU2006
We have better luck with HeliCoil brand inserts than Recoil brand at work.
Old Jun 12, 2012 | 08:49 AM
JRS2's Avatar
JRS2
Ok, thanks guys. If heli coil has better success, I'll go with them, especially in a motorcycle cam shaft retainer application .... It's certainly worth a couple extra bucks if indeed it works better .....
Old Jun 13, 2012 | 07:39 PM
Rogue427's Avatar
Rogue427
Check into Keenserts.
Old Jun 14, 2012 | 05:35 AM
b.wag's Avatar
b.wag
I guess I've used them all- I own a machine shop, and care more about quality than price. The Chrislynn inserts are very good, I've always seen Recoil as the "bargain" brand, Keenserts, well, they're awesome, but you have to drill out the receiving hole bigger, which I don't think you want to do here. The "bottom line" is, I think any of them will work well if you install them correctly. Depending on size, if you don't have a good prewinder they can be a b@#$ to get in, especially the smaller ones- Take your time and make sure the hole is clean of any fod, a small chamfer on the bore prior to tapping will help you with starting the insert.
Good luck!
Old Jun 14, 2012 | 09:02 AM
JRS2's Avatar
JRS2
Thanks guys, just last nite finished tapping and inserting coils ended up using Heli coil and stacking 2 of them. Looking forward to getting this part to the machinist for the line bore.
GOTUBCH
Oct 7, 2012 09:51 PM
Cbronwen16
Nov 11, 2010 09:34 PM
torquemeister
Electrical Systems/Wiring
Jan 31, 2004 03:02 AM
drago
Feb 14, 2001 06:54 PM
