ign coil question
Old Jan 28, 2004 | 03:10 PM
torquemeister's Avatar
torquemeister
ign coil question
Basic question about the ignition coil in my '86:
I was going through the Haynes TFI/Coil testing procedures, and the coil's secondary resistance is 7,600 ohms. The specs are 8,000-11,500 ohms. All of the other checks were ok. Is this enough of a difference to warrant replacement? Would the slightly lower resistance be noticeable in the truck's performance?
Thanks,
TM
Old Jan 30, 2004 | 05:21 PM
bob arrington's Avatar
bob arrington
i would , its my understanding that you need to be within specs, not below them, good luck,bob
Old Jan 30, 2004 | 08:21 PM
thelonerangerxlt's Avatar
thelonerangerxlt
TM, if the coil temperature was below about 70*F, that's why you got a low secondary resistance reading. Warm it up a little and re-check it. I'll bet it's OK.....
Old Jan 31, 2004 | 03:02 AM
Mike W's Avatar
Mike W
If you have a decent spark, I wouldn't worry about it.
