Mechanical Vs Electrical Gauges
Old Jun 22, 2012 | 11:27 PM
lilmatt119's Avatar
lilmatt119
Hey all, tried to do a search but can't really find anything here or on the interweb that explains it layman enough for me.
Basically, I'm planning to add a fuel pressure gauge in the next couple of months (read as next major project). I've been looking into the Autometers, as I know they're reliable and all that good jazz.
Question is, what is the physical differences between mechanical and electrical, and which is simpler to install, more reliable, and what is needed to install either? Any help is very much appreciated as I'm trying to get my gauge this month and get it installed very soon.
Old Jun 23, 2012 | 09:16 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Mechanical fuel pressure gauge is normally screwed into a "T" fitting in fuel line/fuel rail. Not something you need to monitor constantly from cab.
Old Jun 23, 2012 | 09:22 AM
lilmatt119's Avatar
lilmatt119
Well, I plan on forced induction, which is why I'm planning on putting the fuel pressure gauge in cab too.
Old Jun 23, 2012 | 09:39 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Ok. Boost gauge I can see, not fuel pressure, but. Advantage to electrical gauge would be not running a physical line carrying fuel to cab, eliminating a source of danger. While I usually run mechanical gauges, they are simply replacing stock gauges not known for their accuracy. With all new Autometers, electrical should be fine and less danger of leaks.
Old Jun 23, 2012 | 09:45 AM
lilmatt119's Avatar
lilmatt119
So, if I buy an Electrical one from Summit, does it come with everything needed to install it? As far as making it work I mean.
Old Jun 23, 2012 | 10:12 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Just a quick look at one says includes sender and wiring. I'm sure you would have to provide a port for the sender if you do not have one already. Then the issue of mounting location. In dash, pod mount etc.
Old Jun 23, 2012 | 10:55 AM
Beechkid's Avatar
Beechkid
Electric gauges are very accurate...typically less than 1% deviation
Mechanical are slightly more responsive (fractions of a second) than electric- and with the exception of fuel, run fluid carrying line directly to the gauge.
For street cars- electric is all you need-- if a mech hose breaks it makes the inside very messy!
In summary,
Old Jun 23, 2012 | 11:05 AM
lilmatt119's Avatar
lilmatt119
So, I was kinda leaning towards electric before hand, but now I really am. Thank y'all for the help!!
Old Jun 23, 2012 | 05:47 PM
Ken(Ark)'s Avatar
Ken(Ark)
Originally Posted by Beechkid
......if a mech hose breaks it makes the inside very messy!
I will never again use the white plastic hose for an oil pressure line but insist on the copper stuff , which you can get in the small 1/8" diameter.
'80 Futura we swapped the 6 for a 302 , fun little car , anyway the line went brittle after a few years and we accidentally snapped it . Good thing we had the hood up and noticed it before the oil was gone .
Old Jun 24, 2012 | 04:02 PM
lilmatt119's Avatar
lilmatt119
For a boost gauge, how does a mechanical gauge install? The series of gauges I picked for my fuel pressure only has mechanical boost gauges and it's boggling my simple mind
Old Jun 24, 2012 | 04:08 PM
xlt4wd90's Avatar
xlt4wd90
It could use a pressure transducer, like an electric oil or fuel pressure gauge. What kind of line does the mechanical boost gauge use? If it bursts while in use, it's not nearly as dangerous as an oil or fuel line bursting.
Old Jun 24, 2012 | 04:33 PM
lilmatt119's Avatar
lilmatt119
It says that it includes a nylon hose and "t"joint. This is on summit racings website. I'm trying to picture it in my head but can't figure it out lol
Old Jun 24, 2012 | 11:15 PM
Blurry94's Avatar
Blurry94
Look into a boost/vacuum gauge. Just plumb the gauge into your existing vacuum tree or "T" into one of the vacuum lines. LMC has A-pillar gauge pods that will hold up to three gauges.
Old Jun 24, 2012 | 11:28 PM
lilmatt119's Avatar
lilmatt119
So, with a boost/vacuum gauge, you only plumb into the vacuum line, or you have to plumb into the vacuum line /and/ the air intake plumbing?
Old Jun 25, 2012 | 01:00 AM
xlt4wd90's Avatar
xlt4wd90
The boost gauge will be measuring manifold pressure, which could be below (vacuum) or above (boost) atmospheric pressure. You can just use a vacuum gauge with scales above and below zero reading, and plumb it into a manifold vacuum port. Of course, if you will be running a lot of boost, you may need a way to make sure the vacuum lines (or plugs and caps) don't pop off their nipples.
bigred66
Nov 5, 2013 02:19 PM
Chris123NT
Feb 25, 2013 07:52 AM
TurnerBioDiesel
Jun 21, 2010 02:09 PM
jsmahan
Oct 8, 2009 04:24 AM
Scouder
Apr 5, 2004 11:19 AM
