General Automotive Discussion
Small Engine Diagnostics Quiz
Old Jun 10, 2012 | 10:25 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Single cylinder <strike>2</strike> 4 stroke gas powered engine
Customer Complaint:
- Engine was making strange, loud noises
- Engine was emitting smoke from exhaust
- Upon inspection oil was empty
- Customer replaced oil
Personal Observations:
- Large amount of oil around the base of the engine.
- Pull-start cord will not turn over the motor
Feel free to ask questions to see if you can guess what happened.
My first hypothesis turned out to be right was right.
After a few trys, or if someone gets the answer, I will reveal how I came to my conclusion.
Old Jun 10, 2012 | 10:48 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
I'll take a W.A.G.
Customer put oil in crankcase of a motor that doesn't use oil in the crankcase. When they tried to start the motor, oil traveled up through the transfer ports and hydrolocked the piston.
Old Jun 10, 2012 | 10:51 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Originally Posted by SteveBricks
I'll take a W.A.G.
Oops.
My bad Free point to Steve for catching my error.
No the oil was in the right spot. There is an OIL dipstick.
(Maybe he used the wrong 710 fluid haha)
Old Jun 10, 2012 | 10:57 PM
SteveBricks
FTE Emeritus
Overhead valve or flathead?
Old Jun 10, 2012 | 11:02 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Flat head.
Old Jun 10, 2012 | 11:39 PM
Ford_Six's Avatar
Ford_Six
Oil was added after internal parts became external?
That or they filled the oil to the top, locking the engine.
Old Jun 10, 2012 | 11:40 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You're warm.
Old Jun 11, 2012 | 02:55 AM
Pitcrw6's Avatar
Pitcrw6
They thought it was a 2 stroke and added oil to the gas or they added gas where the oil goes
Old Jun 11, 2012 | 05:42 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Sounds like he ran it dry of oil and seized the engine.
Old Jun 11, 2012 | 07:59 AM
19fifty4's Avatar
19fifty4
He broke it. Am I close?
Old Jun 11, 2012 | 01:12 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Answer:
Engine was ran without oil and started to seize. Connecting rod snapped, and cracked the block.
I came to my conclusion by removing the spark plug and inspecting the piston. I was able to push the piston down with a long drill bit. The pull start string would now move about 1/2 inch and push the piston back up, but could not pull the piston down. At this point I disassembled the engine from the machine and confirmed my diagnosis.
A/Ox4
S. California Chapter
Jun 11, 2012 10:33 PM
F0rdF0rever
1983 - 2012 Ranger & B-Series
18
Nov 19, 2005 07:34 PM
fearfactory
Oil & Lubrication
22
Feb 14, 2005 11:12 PM
d0n_3d
Dec 7, 2003 09:01 AM
evenbogey
Oil & Lubrication
Aug 27, 2001 04:52 PM
