Oil & Lubrication
Too much oil in engine
Old Jul 8, 2001 | 05:18 PM
evenbogey's Avatar
evenbogey
What are the symptoms of having too much oil in the crankcase? By too much I mean about 3/4 of a quart.
Old Jul 9, 2001 | 09:32 AM
AZ4x4f150's Avatar
AZ4x4f150
In my past experience of aliitle to much oil. If anything happens you might get alittle leak from the front or rear seal but it will quit after awhille or you just might not have anything happen at all. 3/4 of a quart is not really much
Old Jul 9, 2001 | 10:52 AM
jim henderson's Avatar
jim henderson
3/4 of a quart is usually not enough to worry about. 2 or more quarts get progressively worse. as the oil level rises it will have a tendency to foam, which means that there will be air in the oil and less lubrication, this can damage engine components. You may also get oil blowout from the filler or dipstick and breathers. If you get really crazy, you will burn oil and smoke a lot. In worst cases you will get a lot of oil in the cylinders and the engine will be prone to damage during the compression stroke. Oil doesn't really compress, but engine components will, bad news.
I have never seen damage from hydraulic damage from oil in the cylinders but have heard about it a few places. I have personally put in double the oil and seen the engine smoke and run crappy, thankfully that was a lawnmower.
Don't worry about a quart or less, especially in a truck engine. On a small engine with say 3-4 quart capacity, a quart is more of a problem.
Good Luck,
Jim Henderson
Old Jul 10, 2001 | 06:22 AM
TallPaul's Avatar
TallPaul
I suspect, if anything, the extra 3/4-quart may be beneficial since oil helps cool your engine. By 3/4-quart do you mean the book says 6 quarts with filter change and you put in 6&3/4 quarts (and where then is it on the dipstick?) or did you just put the 6 in and it shows about 3/4 too high on the stick?
Old Jul 10, 2001 | 05:14 PM
billyb's Avatar
billyb
too much oil will lock up an engine. the pistons can't go back down corectly, and force oil up into cylinders . at this point you get hydrostatic lock. i have seen this on several front wheel drive vehicles where owners have let out transmission fluid thinking it is engine drain. then add 4-5 qts. oops!
3/4 of quart should not be an issue.
Old Aug 27, 2001 | 10:36 AM
jim henderson
Old Aug 27, 2001 | 04:52 PM
deadeyeQTX's Avatar
deadeyeQTX
On most 96-present Ford Trucks that I have dealt with (I usually dealt with about 20 a day!), the oil capacity limit, 6 quarts, shows up about half-way on the dipstick. I was taught to never fill a 96-present Ford to the FULL indicator line on the dipstick.
A_Fire_InsideR1
3.8 & 4.2L V6
26
Jan 19, 2024 03:35 PM
fordopie
13
Feb 27, 2018 09:03 PM
DieselCamper
Aug 15, 2016 11:36 PM
ztodd377
Nov 6, 2010 02:07 PM
m_disco
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 28, 2003 02:34 AM
