oil cooler change- mystery part
Hi all, I've searched the web/forum to no avail. I'm in the middle of doing the EGR delete/oil cooler swap. After smacking out the old cooler from the housing, i discovered a small piece on the bench which I'm sure wasn't there before.....
It looks like a check valve of some sort. 1/4 inch in diameter, 1/4 inch long, brass housing. Cylindrical in shape, w/ 4 holes around periphery, 1 steel ball bearing in center. The ball bearing moves up and down to block or unblock periphery holes.
I can't see anywhere it would go in the housing. This thing could have very well been on bench before, but i can't assume. Any one seen something like this in the oil cooler housing?
Thanks! Dave
Thanks! Dave
I didnt see anything in my Oil Cooler housing from the pics I took maybe something in the Filter adapter IDK
Check them out if you want
Ford Truck Enthusiasts Forums - BLADE35's Album: oil cooler
Click here^^^^
There was some brass colored stuff in the Filter adapter is only reson I ask you can see in these pics
Click here^^^^
ok, mystery part identified. Upon installing new thermostat, i recognized the little check valve/air bleed pressed into thermostat housing. I guess at some point this thing broke off an old old one and found its way into the oil cooler then fell out when i smacked the old oil cooler out...
dothedew192
03-18-2024 12:39 PM
