where do i hook up my code reader?
Old Jun 10, 2012 | 02:18 PM
mikerans's Avatar
mikerans
i just got my Equus 3145 reader for my 95 f150 xl..i need it to look up codes for my e40d transmission to see if theres any sensors that are bad. but i dont know where to hook it up at? any helps appreciated.
thanks, mike
Old Jun 10, 2012 | 02:34 PM
Lazy K's Avatar
Lazy K
Fuel Injection Technical Library » How To Run a Self-Test This link shows the STO and STI connectors, you need to plug both into your code reader.
Old Jun 10, 2012 | 03:33 PM
octaneforce's Avatar
octaneforce
if its speed density the plug is on the drivers side fender under the hood behind the fusebox. if its MAF than the plug is inside the cab under the kick panel on the driver side, also near the fuse panel.
Old Jun 10, 2012 | 04:24 PM
cjben's Avatar
cjben
nope. If the truck is a 95,should be in the same place doesn't matter if it is SD or MAF my 95 is MAF and it is on the driver's side inner fender where the fender meets the cowl by the cruise control. 96 started OBD2 for the f150,that diagnostic port should be inside the truck.
Old Jun 10, 2012 | 08:33 PM
octaneforce
obd1 maf. thats a grey area lol. thanks for filling me in.
blacklab1
Jul 1, 2016 12:26 PM
captinphill
1978 - 1996 Big Bronco
Dec 15, 2015 02:26 PM
fud24682000
Aerostar
Jul 9, 2011 08:35 PM
beerfart
Feb 15, 2008 05:16 PM
Bogn
Jan 18, 2005 05:26 PM
