where is code reader plug
Old Feb 15, 2008 | 07:02 AM
beerfart's Avatar
beerfart
I have a 1995 f150 4x4 and the "off" light is flashing on the shift lever.
Everythings still seems to work. However went to autozone to get a code
read and the guy could not find the plug for the code reader. Any idea's
would be appreciated........thanks
Old Feb 15, 2008 | 07:17 AM
TexasGuy001's Avatar
TexasGuy001
The diagnostic connector is located under the hood on the driver side inner fender by the firewall and cowel. Its at the top. It has a 4 pin connector and a single pin connector.
Old Feb 15, 2008 | 07:48 AM
beerfart's Avatar
beerfart
Thank you, I ask him if it might be under the hood and said "no way".
Thanks again for your help
Old Feb 15, 2008 | 09:00 AM
mprice's Avatar
mprice
He was probably looking for the ODB2 port which is usually below the steering column. On my 95 Bronco the plug is six sided - like a squashed school zone sign - and hangs from its wires between the brake master cylinder and the drivers side wheel well. Since your truck is a 95 you will need a Ford ODB1 scanner or a paper clip to get the codes out.
Paper Clip method:
http://www.fordfuelinjection.com/?p=13
I guess I'm too ADHD to count light blinks because I could never pay close enough attention to decipher the flashes. I got an Equus code 3145 for $30 that I keep in the truck.
Calvin
Old Feb 15, 2008 | 09:28 AM
quicklook2's Avatar
quicklook2
that code reader rocks and is well worth the money if you like these trucks.
Old Feb 15, 2008 | 09:47 AM
netscaner's Avatar
netscaner
Auto Zone can only read OBD 2 codes................that's 1996 or newer.
Old Feb 15, 2008 | 09:48 AM
WesternFord's Avatar
WesternFord
Will the Equus code 3145 work on a 1991 f250???
I think it will, do i have the EEC-IV?
thanks
Old Feb 15, 2008 | 09:55 AM
quicklook2's Avatar
quicklook2
yes.
it will read obd 1 codes.
Old Feb 15, 2008 | 10:00 AM
mprice's Avatar
mprice
thanks
I'm sure they have something for you, but best to check with the source:
http://www.iequus.com/product_info.p...gory_id=1_10_3
It says most FoMoCo 1981-1995. It will pull whatever codes your EEC version sets.
Calvin
WesternFord
Sorry, did a little research.....
I do have the EEC-IV and it will work, sorry
Ryan
(maybe i should think before i type)
Old Feb 15, 2008 | 05:16 PM
TexasGuy001
Mprice is right it is like a crooked stop sign, and it does have 6 pins, but the tester only uses 4, and the single wire. If I'm not mistaken I think that only 4 pinouts are actually used in the connector.
