Associated HD Plug-In Cable Set 800
Old Jun 10, 2012 | 07:30 AM
Mikeyc187's Avatar
Mikeyc187
I am looking for some advise on installing a jumper cable system. I am wondering if it matters witch battery I hook the receiver box up to. I have had better luck jump starting equipment with my passenger side battery so I am leaning toward that side.
6146 Associated HD Plug-In Cable Set 800 Amp Polarized Socket Box 30ft
Mike
Old Jun 10, 2012 | 07:52 AM
Fontana's Avatar
Fontana
Check out your owners manual. It states that when using jumper cables use the battery on the passenger side. What is a jumper cable system? I imagine this is for a fleet vehicle? Just curious.
Old Jun 10, 2012 | 08:05 AM
sdetweil's Avatar
sdetweil
Mike
wow!.. things have gone crazy with wire prices..
here is a 4ga system, for under $200.
Jump Start Kit, 1250 Max Amps, 30Ft - Jumper Cables - Automotive Maintenance Tools - 3MKE4 : Grainger Industrial Supply
Old Jun 10, 2012 | 06:45 PM
porthole's Avatar
porthole
I added a similar setup using cables and battery connectors from McMaster-Carr.
I ran 2/0 welding cable from the engine to the rear bumper. There I use industrial battery connectors to attach my trailer, boat winches, jumper cables even a portable inverter. Whatever we have that may need high DC current.
The positive cable is connected right at the starter lug, this utilizes both batteries.
The ground is attached to the engine block.
The positive cable runs about 18" to a 300 amp fuse, then back to the bumper.
Old Jun 11, 2012 | 06:09 PM
Mikeyc187's Avatar
Mikeyc187
I think I will use the passenger battery for the negative and the starter lug for the positive..
whitesdford
Sep 11, 2007 10:03 PM
MAKO314
Aug 5, 2007 06:16 PM
ggirten
Jan 10, 2006 11:35 AM
stupidjet
Feb 4, 2005 06:32 PM
Overfences
Apr 7, 2002 06:29 AM
