engine losing power
Old Jun 17, 2012 | 05:54 PM
Locorotc's Avatar
Locorotc
Anybody know what I can do to troubleshoot the new issue?
Old Jun 17, 2012 | 08:51 PM
SCRebel's Avatar
SCRebel
Have you checked the relay?
Old Jun 19, 2012 | 04:51 AM
Locorotc's Avatar
Locorotc
I havent yet, I was thinking about checking that next. Is it possible the relay has gone bad again?
Old Jun 19, 2012 | 11:13 AM
SCRebel's Avatar
SCRebel
It's possible. If it has, then it means there is something wrong and its blowing the relay. Or the relay is a defect.
Old Jun 19, 2012 | 02:00 PM
Locorotc's Avatar
Locorotc
Ok thanks I'll check that and post back the results
Old Jun 21, 2012 | 08:38 AM
Locorotc's Avatar
Locorotc
Replaced the two relays yesterday and still the same thing. I'm at a loss now, I have no idea what to check, please somebody help.
Old Jun 21, 2012 | 09:26 PM
Locorotc's Avatar
Locorotc
Pulled the front sending unit to find out if the fuel pump was still working and it indeed Is still working. However, I used the test light to find out if I was getting power to the sending unit and still nothing. I started as far up as I could and found out that after the power comes out of the switch for the dual tanks, it ends somewhere shortly after. I ran a wire straight from the switch to the pump and it turned on. Went to start it, now that I had fuel flow and it started and then stopped again just like before. I have been told the computer has a possibility of being bad. Can somebody agree with that statement or is it something else?
koski19
May 8, 2020 01:35 AM
spocky1187
Mar 15, 2013 10:32 AM
georgiaboy6279
Jun 11, 2011 09:20 PM
Pablo-UA
Aerostar
24
Jul 4, 2008 10:54 AM
jnye6625
Oct 10, 2004 09:11 PM
