1994 F150, digital odo. doesn't light up?
The cover actually has a diagram showing what each one is for, and its placement...
Didn't notice what amps the fuse was suppose to be, I'll have to look again next time I go to it. But looks like theres a short somewhere.
F250XLT:
For 250$ for a running driving 4x4 stick truck, I couldn't say no Doors and cab are mint! I'll post up pictures later on.
on
Well here she be!
Shes got character to
Now don't judge a book by it's cover....
The only rust on the cab, is on the corners... they aren't gone through yet thankfully, still easily repairable.
Drove it straight to storage, a 20 min drive on country roads. Drives actually very nice, has a slight pull to the right, but other than that, it's great! Clutch seems good, shifts good in all gears (stupid M5OD though....) not a huge fan of that tall reverse gear! At least it's 4x4, so low range will come in handy to correct that. 4x4 works (auto hubs), oil is clean in engine, runs super smooth and quiet, fires right up.
Now the bad..... not much to list, but it hasn't been plated and on the road for 6 years, it's been running around in a parking lot for 6 years. It was used as a fuelling truck in an auction. So that's not good. Also gonna need front tires, and probably an alignment, wheels are straight camber wise, but has that slight pull. That's about it.
You should have "2" fuses for the psom.
One is a 10 amp and the other is 15 amps.
Here's a diagram of the left part, pic was two small, so I had to split it in two.
Lightgreen/yel and pink/org are the power lines.
Follow the others to find your fault.
Here's the right side, continued.
You'll see...wires 4 and 5, change into wires 1 and 2 on the far right.
The next pic shows these continuations.
They go to your vss.
77_150
03-13-2015 03:53 PM
rcaryl
01-05-2005 09:26 PM
4ced2work
02-02-2004 01:03 PM
