93 f250 5.8l fuel pump/selector problem? - Ford Truck Enthusiasts Forums
Old 06-10-2012, 11:06 PM
mkl55
mkl55 is offline
mkl55 is starting off with a positive reputation.
gotta 93 f250 5.8L with duel tanks with some fuel delivery issues.... has a hard time starting on EITHER tank, when i turn the key to "on" i can hear the pump engage when the dash switch is on the front tank or rear tank, but wont start.... i have to turn the key to "on" anywhere from 4 to 20 times before i hear a "clunk" after i hear the pump engage, assuming its a tank selector valve?..... the problems getting worse and worse especially on cold start, less of a problem when warm.
anyway i can just eliminate this problem cheap and easy? i could care less if i lose the use of one of the tanks, i do have fuel transferring from back to front also.
Old 06-11-2012, 04:34 AM
XLT89F350cc
XLT89F350cc is offline
XLT89F350cc is starting off with a positive reputation.
change the fdm (sending unit an pump). whats ur fuel pressure at the rail while running ?
Old 06-11-2012, 07:33 AM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
That vintage truck doesn't have a selector valve so your problem is inside the tank and it's related to the fuel transfer problem, so as already mentioned you need to drop at least one tank(but probably both) and replace the FDMs.
90150xlt
12-10-2015 06:33 PM
vacuumbed
07-16-2014 04:24 PM
biztyke
06-12-2013 01:27 AM
Franken-Truck
Electrical Systems/Wiring
12-18-2011 06:20 PM
mdm350
15
03-16-2010 09:52 PM
Quick Reply: 93 f250 5.8l fuel pump/selector problem?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
