Darksider Questions
Heres the breakdown. Recently put a 1976 Pontiac firebird Formula front clip under my 1955 F100. I "had" a 400SBC in it, until it had catostrophic failure. I had stock exhaust manifolds. I had to weld the motor mounts a little forward of where stock was, due to the dist hitting the firewall. I have since pulled the ruined 400, and am having a 383 stroker built.
Can anyone recommend headers that will work for me. The problem is that because the motor mounts are mounted forward of stock, most header applications come down and hit the control arm. I need headers that really dont "Drop" until after the third port. I am fairly new here and havent figured out how to do pics yet. I am hoping there is someone out there that has a similar set up to me. Any help is greatly appreciated.
Thanks everyone!
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
http://i285.photobucket.com/albums/l...ghtsafter1.jpg
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
I'm sure some others will be along shortly to tell you to put it back all Ford and you won't have those problems. Just goes with the territory that you venture into.
________________________________
46 Ford Tudor - Street Rod
48 Ford F1 - Darkside
"If you drive a Chevy you need a Good Wrench"
These are Sanderson cc 11, sbc in 72 c10 chassy I'm far too tight at the firewall as well.
