1985 bronco sticker decode
Old Dec 29, 2013 | 05:18 PM
1985 Bronco's Avatar
1985 Bronco
Ctubutis, you have been very helpful recently! You said you decode this?
Old Dec 29, 2013 | 05:33 PM
bruno2's Avatar
bruno2
Picture no worky.
Old Dec 29, 2013 | 05:47 PM
1985 Bronco
it's really hard to do this on your phone
Old Dec 29, 2013 | 05:55 PM
arctic y block's Avatar
arctic y block
Could we see some pictures? Here is how.
But I got ta say becoming a supporter is the fastest and easiest way to post pics right from
your whatever pad/cell thing or home computer.
Few of us look in the users Gallery or album as you can see by your recent visitors.
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
Quote:
Originally Posted by old_dan
You can also go to the "Garage" tab and start an album right here on FTE. After you post pictures to an album, we can look in your album, but you'll also be able to "insert a picture" by pasting in a link to the picture in your album.
It seems awkward, but whenever you "insert a picture" to one of these threads, the forum is looking for the picture somewhere on the web (which is always available) rather than from somewhere on your hard drive (which isn't always available).
Quote:
Originally Posted By Jolly Roger Joe
Welcome to FTE!
Go to Image hosting, free photo sharing & video sharing at Photobucket and sign up for a free account. Then create an album for your truck. Upload any pics you want to post on FTE to that album. Have this album open on your computer when you want to post pics on FTE.
While you're making a post on FTE, select the pic you want to post from your Photobucket album. When the large version of the pic is open, right mouse click on it and select "View Image Info". The image info will be highlighted and will look something like this:
The best photos and videos | Photobucket
Copy that highlighted info (right click / copy).
When you have the spot in your post where you want the pic to be placed, select the "Insert Image" icon at the top of the post (looks like a mountain) and paste (right click / paste) the image info you copied in the highlighted box (just shows "http://" when it opens).
Your pic will be placed in the post.
Hope that helps.
Here's a tutorial Bob put together: https://www.ford-trucks.com/forums/67...-pictures.html Bob's link is not working. Can someone in the know tell me why?
How to upload pictures to the FTE Forums. - YouTube. Thanks Sam Rusty_Old_F250. Best we can find is that this video was done by Gundown64
Old Dec 29, 2013 | 06:00 PM
1985 Bronco
I understand how to do it, the HAMB is the same way, I was doing it on my cell phone which is much more difficult, I'm on a computer now. Thanks for the welcome!
Old Dec 29, 2013 | 06:16 PM
ctubutis's Avatar
ctubutis
I should be able to get to it here in a while (after dinner).
BTW I don't read sideways real well....
Old Dec 29, 2013 | 06:19 PM
1985 Bronco
thank you!
Old Dec 29, 2013 | 06:52 PM
bruno2's Avatar
bruno2
Axle code H9 = 3.55:1 Limited slip rear end. I am sure it is the 8.8 and not the 9"
Trans code K = C6 Automatic.
Old Dec 29, 2013 | 07:23 PM
bruno2's Avatar
bruno2
Eat your damn dinner for crying out loud. I am sure it's just Ramen noodles or Mac and cheese.
Old Dec 29, 2013 | 08:21 PM
ctubutis's Avatar
ctubutis
You forget that my mom moved in with me ~1 year ago, she does most of the cooking.
Originally Posted by 1985 Bronco
thank you!
Here ya go....
1FM D U15 Y 3 F L A98129
1FM = WORLD MFR. IDENTIFIER = Ford Motor Company, USA, Multi-Purpose Vehicle/Bus
D = BRAKES/GVWR CODE = CLASS D = 5,001-6,000 LBS.
U15 = SERIES CODE = BRONCO WAGON, 4WD
Y= ENGINE CODE = 4.9L/300 cid 8-CYL GASOLINE-POWERED, FEEDBACK CARB OR EFI
3 = CHECK DIGIT (IGNORE, FOR FOMOCO USE ONLY)
F = MODEL YEAR CODE = 1985
L = ASSEMBLY PLANT CODE = MICHIGAN TRUCK
A98129 = NUMERICAL SEQUENCE OF ASSEMBLY
TYPE = MPV = MULTIPURPOSE VEHICLE/BUS
EXTERIOR PAINT COLORS = 7H = BRIGHT REGATTA BLUE METALLIC ACRYLIC LACQUER
DSO 47 = DISTRICT OF ORIGINAL-PURCHASING DEALER = CINCINNATI
F0042 = 42 lbs. of accessory equipment (e.g. plow) can be placed on the front axle without requiring recertification
T0447 = 447 lbs. total weight of accessory equipment (front + back) w/o requiring recertification
WB 105 = 105" WHEELBASE
TYPE-GVW U152 = BRONCO WAGON, 5,950 lb. GVWR
BODY AB = MATERIAL AND TYPE OF SEAT = BLUE ALL-VINYL BUCKET SEATS
TRANS K = FORD C6 AUTOMATIC
AXLE H9 = 3.55:1 RATIO; 3,750 LB. CAPACITY; MADE BY FORD; LIMITED SLIP
TAPE = OPTIONAL TAPE STRIPES TYPE
SPRING U Z =
U = FRONT SPRING IDENTIFIER - F4TZ-5310-H REPLACEMENT PART NUMBER (replaced original E0TZ-5310-L springs)
Z = REAR SPRING IDENTIFIER - E0TZ-5560-AD REPLACEMENT PART NUMBER
The parts book has no real information on springs other than replacement part numbers, you might Google the numbers for more info if you're interested
Source: FoMoCo 1980/89 Light Truck Master Parts Catalog (available on CD from hipoparts.com)
Old Dec 29, 2013 | 08:50 PM
bruno2's Avatar
bruno2
Is the description in your profile accurate for the Bronco? It says 460 punched out to 475. Is the trans still an auto? Your rear ends may not even be what the truck came with originally either.
Old Dec 29, 2013 | 09:40 PM
1985 Bronco
yes, it has the stock rear end and either a newer c-6, or a rebuilt stock one. I was told that there was between 5000-8000 miles (odometer not hooked up) on the engine, tranny, suspension, and tires when I bought it.
1918ALF
Aug 27, 2013 07:47 AM
cptntrtl
Aug 18, 2013 10:29 AM
hanksy
Aug 17, 2013 08:07 PM
flyin 51
Oct 4, 2012 12:01 PM
karjunkie
27
Oct 2, 2012 10:34 PM
