I am T/S a misfire on my daughters 2003 Ranger, 3.0L. I have consistenty pulled a P0303 & 0316 code (cylinder three misfire & multiple misfire) . I switched the number three and four spark plug wires at the ignition module. Now I get a P0304 & P0316 code. This would lead me to believe the ignition module is bad since those two are fired in pairs. Correct?
Kinda sounds that way. You could do an ohms check of that coil across the 3-4 plug wire terminal & compare its resistance with the other pairs reading, or have the autoparts store bench check the coilpacks output, as most have a tester & they'll do it at no cost.
If you opt for a new coilpack, have it bench tested before leaving the store with it!!!!!
Thanks in advance,
Ken
Let us know how it goes.
pawpaw...me confused.......his truck does not have a separate ignition module.....I guess he is talking about the coilpack?.........pawpaw I would think that if the misfire was following the sparkplug wire then it would indicate a bad wire not necessarily bad coilpack......thoughts?
At first read, my thoughts were plug wire too, but after re-reading his post & noticing that he swapped the plug wires at the coilpack, it seems that the #3 half of the coils secondary winding has a problem.
pawpaw....good reading between the lines.....I did not notice that......so he just swapped the wires only at the coil-pack(what he is calling the ICM).....I never heard of anyone T/S like that before....but if it worked for him!!!...I would think that it could cause a misfire at both cylinders since both cylinders might not be running at 100% thus causing the crank feedback to notice an rpm difference and throw a misfire code for each cylinder............He should test for secondary resistance between the #3 and #4 sockets to help confirm is DX...he wants 13k-15k ohms
Since he only had a trouble code for the #3 cyl, not the #4 cyl, which uses the other half of that secondary winding, by switching the plug wires at the coil pack, on our waste spark ignition system that fires the plugs on every rotation of the crank shaft, he was just exchanging coil halves & reversing spark polarity to the plugs, to check the plug wires & both halves of the secondary winding.
If the misfire had continued to be on cyl #3, then suspect the #3 plug wire, spark plug, fuel injector, or a compression problem on #3 cyl.
Since #4 had been firing ok, but switching its plug wire to the #3 side of the secondary winding & having the misfire switch to #4 cyl, suggests that the coilpack #3 secondary half of that winding has a problem.
Maybe a broken secondary wire, shorted windings, or maybe a case crack underneath thats letting voltage leak or arc to ground, causing a weak or no spark condition.
Case cracks underneath are common. Would be interesting to hear whats found.
Since #4 had been firing ok, but switching its plug wire to the #3 side of the secondary winding & having the misfire switch to #4 cyl, suggests that the coilpack #3 secondary winding has a problem.
Thanks pawpaw..........now I get it..........does sound like the CP..........
I'll get a coil pack on order and get back to you with the results.
Pawpaw; excellent details on how it works. That was exactly what I was looking for.
Thanks,
Ken
Hold on, before you order, do the secondary resistance check between the coil pack #3 & #4 plug wire connection terminals that powersmoked suggested, or lift the coilpack on an insulator & look for arcing at idle, when you spritz it with a spray bottle of water. If you get a positive, Then spend your gold!!!!
Results of new coil pack: Hallelujah! Idle smoothed out, no misfire and as a bonus no more shuttering power loss under load; which, I was thought was another problem.
Thanks all,
Ken
Good find fix & feedback & Thanks for closing out your thread.
