Bronco II Ford Bronco II
ignition coil wire
Old Jun 16, 2006 | 06:32 PM
my72ford's Avatar
my72ford
ignition coil wire
on my 86 b2, there is a coil mounted on the driver side fender well with 2 wire that plug into it. 1 green wire and a red wire.on the red wire there is a gray connector plug that is just hanging,i cannot find where this plugs into,is this just a test plug?can anyone tell me where it might plug into?any help is appreciated as always
dj
Old Jun 17, 2006 | 05:32 PM
rebocardo's Avatar
rebocardo
A condensor plugs into it to clean up the power for the radio? I will double check my CD to be sure.
Old Jun 21, 2006 | 02:18 PM
ivypunk's Avatar
ivypunk
I believe that plug goes to the capacitor, there should be a cylinder-ic shaped object mounted on the base of the coil to the right of the two red wires with a matching plug on it.
