tires
Old Jun 6, 2012 | 10:26 PM
dcullen's Avatar
dcullen
tires
Hi -
I have a 1993 7.3 IDI Diesel, rear wheel drive...what size tires fit on this truck ?
I have a friend with some spare tires that might fit - the size of these potential tires are :
P285 50R20M 4 S
Does anyone know if these would fit ?
Thanks,
Doug
Old Jun 6, 2012 | 10:34 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Most of that is entirely too vague to give an accurate answer, but i can almost promise those tires will be nowhere close.
Stock tire size is 235/85/16, dually is 215/85/16. 235s are a bit narrow, 265/75s are a bit wider but more or less the same height. I would go with either of those in a D or E load rated casing. If you want a little bigger than stock go with 255/85/16 (narrow) or 285/75/16 (wider)
the 20's you mentioned will, to say the least, not work, and if i may be so bold, a 50 series would look terrrible on a pickup. Besides all of that, they are a car tire, indicated by the P meaning 4ply rated.
19
Sep 7, 2011 07:46 PM
tha-yoter
Nov 16, 2009 09:25 PM
Mat J
May 1, 2009 04:24 PM
sammy77
Oct 30, 2007 05:55 PM
dgodude
Aug 30, 2002 04:45 AM
