Carb leakdown problem
Old May 6, 2003 | 12:33 PM
old hippy's Avatar
old hippy
1985 YFB feedback. I just rebuilt this carb as part of a semi restoration project. Over night the float bowl empties out. I can see the intake manifold is damp right under the carb and it appears there is fuel in the crankcase. I have double checked all screws and the float adjustment.The overall condition of the carb after initial cleaning looked good (it even had the tag). Any thoughts as to what I have done wrong or overlooked would be greatly appreciated. thanks
Old May 7, 2003 | 09:22 PM
broncr's Avatar
broncr
'sounds like a similar problem to the one Kevinken has - "Carb problem" . Wish I had an answer. Those feedbacks were problematic.
Old May 8, 2003 | 01:05 AM
Ford_Six's Avatar
Ford_Six
It sounds like the air bleed in the idle circuit is plugged, if you meant that the inside of the intake was damp. If it's the outside, could be a porous casting, scratch on a mating surface, a misaligned gasket, etc.
Old May 8, 2003 | 01:11 PM
old hippy's Avatar
old hippy
problem solved. from now on i will check the "L" shaped cardboard float gauge that comes in carb kits with a micrometer and caliper before adjusting floats. thanks for the replies!
Old May 8, 2003 | 01:30 PM
millertime300's Avatar
millertime300
If you are getting fuel in your crankcase, that is the fuel pump. Maybe you have two problems at the same time.
mh34444
Sep 27, 2009 03:24 PM
quintcy
May 22, 2007 10:03 AM
Flathead47
1947 and Older Ford Trucks
Dec 15, 2006 10:47 PM
51f1
Oct 3, 2004 10:43 AM
ClatonK
Jan 4, 2004 11:20 PM
