Engine Clatter on Startup
Old May 6, 2003 | 01:02 PM
doczog's Avatar
doczog
MY 1990 6 banger sometimes (not always) bangs like crazy for a few seconds on startup.
I does not always do it, but it is sure scary when it happens.
THe truck only has 78,000 miles and does not use oil or smoke.
Any Ideas?????
Old May 6, 2003 | 03:37 PM
Chas1234's Avatar
Chas1234
What brand of oil filter are you using?
millertime300's Avatar
millertime300
Hate to say it, but it sounds like main bearings. Does it ever made noise under heavy load at low rpms?
If it does, (and it isn't pining) just use heavier oil untill you feel like rebuilding it.
Old May 6, 2003 | 03:42 PM
Chas1234's Avatar
Chas1234
Main bearings may not be the problem I think it is the rod bearings .
If you are not running a motorcraft oil filter the 300 will knock like crazy .
Get the Fl-a1 filter at a part store and your engine will not knock!
My 300 had 149000 miles on it when I bought the truck . It didn't have the motorcraft filter on it and it too knocked at start up . I switched it out and no more problems .
Old May 6, 2003 | 03:49 PM
billyb's Avatar
billyb
I agree with the oil filter issue. Get one with a good anti drainback valve. (Wix, Motorcraft,) . Also watch for parking on excessive angles. My truck clatters more if I park on side slope of driveway !! Go figure.
Old May 7, 2003 | 09:47 AM
doczog's Avatar
doczog
I am currently using a Ford Motorcraft FL1A filter...does not seem to make any difference.
I believe the bearings are fine, as the oil pressure is good, and I keep the oil clean. I am using 10w30 Valvoline and may switch to 10w40 next time, just to see if it makes any difference.
Also, I am going to try a WIX filter next time...this has been recommended before...thanks
Old May 8, 2003 | 07:01 PM
Iman's Avatar
Iman
The filter is astart to the problem, The ford 300 does not have a check valve in the filter system to stop the oil from draining back into the base pan after the engine is shut off. The oil drains out of the filter and the clatter you hear is just verious engine parts such as valve train making the noise on startup. There is an adapter that that screws on before the oil filter, but I'm not sure where you might get it. It was intended for the 302 but does work on the 300.
tobyw
2009 - 2014 F150
Oct 6, 2015 03:56 PM
Blacknav
25
Sep 20, 2015 07:38 PM
BCM
6.7L Power Stroke Diesel
17
Mar 15, 2015 10:27 AM
Aftrmidnite
General Automotive Discussion
Jan 2, 2015 04:22 PM
WRHadam
Oct 24, 2014 07:45 AM
