gauges not working?
Old Jun 4, 2012 | 05:25 PM
koenig1965's Avatar
koenig1965
Question gauges not working?
I forgot to disconect the 4 prong trailer conection from my boat last time i pulled the boat from the water and have had no dash gauges since. At the time i got a flat from some rebar sticking out of the boat ramp and had to pull out to fix it. If i remember it seemed the truck had low power and would not shift into 4x4. Also the OD button does not work. Everything else works fine. I have looked at all the fuses and they seem good. Should I replace the ones for the Instrument panel regardless if they look good or not incase there not working. Any ideas would be helpful as I am running out of ideas. Thanks
Old Jun 4, 2012 | 05:34 PM
projectSHO89's Avatar
projectSHO89
Check fuse F29. If blown, SEARCH keyword "F29".
Pretty common.
Old Jun 6, 2012 | 09:55 PM
koenig1965's Avatar
koenig1965
you are da MAN projectSHO89. problem fixed....thank you I owe ya
msriverrat
Jan 13, 2011 10:39 AM
koolmotor
Sep 20, 2010 04:49 PM
cjh2os
1997 - 2003 F150
Aug 16, 2006 02:00 PM
f1walt
Oct 12, 2005 09:01 AM
