E-Brake Light
Old Jun 4, 2012 | 11:17 AM
awright48's Avatar
awright48
E-Brake Light
Of course the month my inspection is due, my e-brake light comes on, and I have no clue why. I use my ebrake religiously. Any ideas, thoughts?
Thanks!
Old Jun 4, 2012 | 06:31 PM
critterf1's Avatar
critterf1
Check the brake fluid level.
Old Jun 5, 2012 | 12:02 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
That little switch for the parking brake can break rather easily, just happened to me February or so.
Take a look by the bracket you might just a wire hanging loose with a piece of it still attached.
Josh
Old Jun 5, 2012 | 06:31 AM
Dan Robertson's Avatar
Dan Robertson
I have to pull up on the e-brake peddle with my toe while holding out on the release to get the peddle to come up enough to get the light to go out.
Old Jun 5, 2012 | 06:54 AM
awright48's Avatar
awright48
What's the chance of it having something to do with the ABS? I was reading up on some explorer forums as I was waiting corresponded.
Old Jun 5, 2012 | 06:58 AM
critterf1's Avatar
critterf1
Normally you would have an ABS light on also.
Old Jun 5, 2012 | 04:53 PM
Dan Robertson
Critterf1 is correct. If you had an ABS problem, that light should come on. I ruptured a rear brake line a few years ago, which caused both lights to come on. The red light with the word BRAKE showing indicates that you have low fluid or, your e-brake is on.
Old Jun 5, 2012 | 05:43 PM
Bullitt390's Avatar
Bullitt390
The part about having to lift up on the parking brake pedal to turn off the light should be a clue as to the problem...
Nothing about low fluid.
Nothing about ruptured lines.
Nothing about ABS.
Hmmmm..... just what could it be?
Josh
Old Jun 5, 2012 | 06:04 PM
awright48's Avatar
awright48
What would cause low fluid, other than a leak?
Old Jun 5, 2012 | 06:13 PM
Bullitt390's Avatar
Bullitt390
Is there a reason your asking about brake fluid when you should be looking at the parking brake switch?
But anywho... Fluid can leak externally from a line or piston or internally into the brake booster which then gets sucked into the engine.
Josh
Old Jun 5, 2012 | 06:38 PM
Furyus1's Avatar
Furyus1
Nothing about ABS.
Josh
It would be a clue - if it were posted by the OP - which it wasn't...
Maybe the OP (awright48) can try this trick and see if he can get the light to go out. I have to do this on my '04 but my brakes are in pretty bad shape lol...
Old Jun 5, 2012 | 06:41 PM
Bullitt390's Avatar
Bullitt390
Missed that part... it's hard to follow in a maze of cluster $%^&
Josh
Old Jun 13, 2012 | 12:15 PM
awright48's Avatar
awright48
wow...well it was a pin hole leak, that I did not see at first, which then got bigger and finally burst. I had to replace my right front brake line...if I wasn't busy I would have saved $290. Oh well. thanks for all the help!
PhillyB
Jun 9, 2024 09:48 PM
joshjack
Oct 8, 2022 05:06 PM
eakermeld
27
Jan 2, 2015 08:33 PM
weekendwarriorfsw32
Sep 1, 2009 02:36 PM
94BlackF150
1997 - 2003 F150
Jan 31, 2005 10:17 AM
