clutch fan ?
Here is a form to check:
Crank the vehicle. Take a broom and use the bristle end to try and stop the fan. You can stop any of them even with a good clutch so that’s not the part your looking for but if it seems like it doesn’t want to stop to the point its scaring you then stop there and rest assured the fan clutch is fine.
If it does stop don’t count it as bad yet. What you want to see is how fast it spins back up when you pull the broom bristles off of it. If it seems to slowly start spinning again then the clutch is bad. If it starts back to spinning almost instantly it’s a good clutch. Bad clutches also don’t pull on the broom when stopped. It’s like it’s not connected at all.
Also for the record for the flaming I’m sure I'll catch from this, you don’t just RAM the broom in there either. Use the brush part to slow the fan down till it stopped or refuses to stop easy.
Anyone that comments after this with anything about "id never do this" or that’s crazy, etc. Its been used for years by mechanics to test fan clutches and if you have old enough service manuals "pre 80's era" its in there as a test method.
And here is a link:
TheDieselStop.Com Photo Hosting - Clutch fan test part A
When it kicks on, you will clearly heard a different big sound.
FAN CLUTCH TEST
NOTE: The following test does not apply to the 6.0L diesel. For the 6.0L diesel, refer to the Powertrain Control / Emmisions Diagnosis (PC/ED) manual.
Spin the fan blade (8600) by hand. A light resistance should be felt. If there is no resistance or very high resistance, the minimum and maximum fan speeds must be checked as follows:
Fan Clutch Test — Minimum Speed Requirement
Use a suitable marker to mark the coolant pump pulley (8509), one of the fan blade retaining bolts and the crankshaft pulley (6312).
Connect a tachometer to the engine.
Install a throttle adjusting tool.
Connect the Digital Photoelectric Tachometer.
WARNING: To avoid the possibility of personal injury or damage to the vehicle, do not operate the engine until the fan blade has been first examined for possible cracks and separation.
Start the engine and run it at approximately 1,500 rpm until the normal operating temperature has been achieved.
Operate the strobe light at 3600 rpm for 7.3L diesel engines, and aim it at the coolant pump pulley. Adjust the engine speed until the light flash and the coolant pump pulley mark are synchronized.
Aim the strobe light at the fan blade bolts. Adjust the strobe light until the light flash is synchronized with the marked fan blade bolt (the fan blade appears to stand still).
The fan blade speed must not be greater than 2,000 rpm on 7.3L engines.
Turn the engine off.
If the fan blade speed was greater than 2.000 rpm on 7.3L diesel engines, install a new fan clutch (8A616).
Fan Clutch Test — Maximum Speed Requirement
Perform Steps 1 through 5 of the Fan Clutch Test—Minimum Speed Requirement.
NOTE: The temperature of the air hitting the fan clutch should be above 96°C (205°F) for maximum fan speed.
Block off areas on each side of the radiator in the engine compartment and the front of the radiator grille (8200). This will raise the temperature of the air striking the fan clutch and should cause the fan blade to operate at maximum speed.
Place the climate control function selector switch in the MAX A/C position and the blower motor switch in the HI position.
Adjust the strobe to 3,600 rpm for 7.3L diesel engines.
Start the engine and adjust the engine speed until the strobe light flash and the coolant pump pulley mark are synchronized.
Aim the strobe light at the fan blade retaining bolts. Adjust the strobe light until the light flash is synchronized with the marked fan blade bolt (the fan blade appears to stand still).
If the fan blade speed is less than 2,850 rpm on 7.3L engines, install a new fan clutch.
