clutch fan ?
Old Jun 5, 2012 | 04:07 AM
richdawg's Avatar
richdawg
Thanks Jose that was some great information. I'll give mine the broom test in the morning ( the wife just got back with the broom.)
Seriously I think mine is working OK, it has a little friction when I try to turn it. I remember trying to turn it a couple of months ago and it seemed to be as you describe.
Old Jun 5, 2012 | 07:51 AM
Talyn's Avatar
Talyn
I just removed mine.
So easy to work on the truck now.
Old Jun 5, 2012 | 08:53 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thumbs up
Originally Posted by fordpride
Great info Jose I tried to rep you but I'm in jail
Originally Posted by ReBilld
I got him!
Originally Posted by Talyn
Make that another.
Originally Posted by oldbird1965
tried but can't
Muchas gracias AMIGOS.
Old Jun 5, 2012 | 01:06 PM
richdawg's Avatar
richdawg
Talyn, I think I remember when you took the fan off last fall or winter. How is it working for you now that the weather has warmed up. Can you tow without watching the temp gauge all the time? I imagine your had to go with a more accurate temp gauge because the stock on really won't tell you much.
Old Jun 5, 2012 | 07:33 PM
oldbird1965's Avatar
oldbird1965
Mine does Rich, what ever my aux gauge says, the stock gauge agrees with it. Thru the years I have heard that the stock gauge is worthless, I must have gotten a good one.
Old Jun 5, 2012 | 08:25 PM
richdawg's Avatar
richdawg
That is interesting that they kind of correspond but how do the temperature degrees relate to the letters on the stock gauge L (NORMAL).H are we OK with the needle anywhere in the normal range between L & H ?
Old Jun 6, 2012 | 09:44 AM
oldbird1965
My aux gauge runs from 205* to 220*, yes, that is to hot. On my list of 'to do's' is to put the stock thermostat back in. The stock gauge runs from about a 1/3 over from the left to straight up and down. I would have to go look to see what letters that is. When I'm at 220* and straight up and down I'm on a hard pull.
Old Jun 6, 2012 | 10:19 AM
Talyn's Avatar
Talyn
When I did my water pump I took it off and left it off.
I run about 210-213 on the highway, and it actually cools off when sitting still. That surprised me, but the scan gauge gives you good info.
I pulled 10k yesterday and my truck actually ran cooler with the bigger load.
On another note, my goose neck hitch is a little loose.
In the heat down here, the most i've seen on the highway was 215 running 70 in 90+ weather.
One thing to remember about my cooling system is it has some major leaks and is not running 100%
My radiator has 3 or 4 leaks in it.
The bypass filter and SCA charge seem to really help though.
Old Jun 6, 2012 | 11:36 AM
richdawg's Avatar
richdawg
That is some very impressive information, it may be something others would like to try. I don't think it would work very well for me or Glenn though towing 14 to 16k. Did you notice any power gain?
Old Jun 6, 2012 | 11:52 AM
oldbird1965
I went to all the trouble to build a oil cooler but left in my 203*??? Sometimes I wonder about my self, LOL. I don't think I would try it without the clutch. I've read on here years ago its a 15-20 hp gain without it which I find hard to believe. That sucker is heavy though!!
Old Jun 6, 2012 | 11:56 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
We too (and NOT SOMETIMES).
Old Jun 6, 2012 | 02:23 PM
oldbird1965
I think you missed your calling in life Jose, you should have been a comedian!
Old Jun 6, 2012 | 04:48 PM
  #28
ReBilld's Avatar
ReBilld
LOL!! That's a good one Jose! I thought me and Mike were the only ones who gave Glenn a hard time!
Old Jun 6, 2012 | 05:51 PM
  #29
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Where is George anyway, I think that Glenn miss him too.
PS, since now Im going to respect his beard.
Old Jun 6, 2012 | 06:06 PM
  #30
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Glenn, maybe you are right. The reallity is that I want to have good time with my friends and myself when possible. Some time ago I met some American people in one RV park in Mexico and the wife of one of them called me "rascal", I really dont know what exactly that means. I hope it has a good meaning. IDK. BUT I transalted like a" PICARO" in spanish.
