4R100 Stage1 Rebuild
#106
Mark,
I suspect John Wood knows how and why the bypass valve and tube works. He's a smart guy, and is only MIS-quoted here by some less-knowledgeable. I suspect he believes his trannys will never-again clog a cooler, and therefore finds them an unnecessary point for potential failure.
It's kinda' a roll-of-the-dice. If one clogs a cooler, one already has a big problem, and it's just a matter of degrees (pardon the pun) about what it's going to take to get it right again.
Early-on, I considered buying a kit to eliminate the bypass, but have since decided otherwise. It was your first-hand, expert testimony that turned the tide for me!
Mine's still there, still doin' its job!
Pop
Pop
#107
Well after Mark gave me all the specs I needed to check to see what was going on as far as my cooling circuit. And after checking everything I don't have an issue with it.
But after installing the trans temp gauge from my motorhome. (Motorhome is no longer trapped under tree) I installed a Ultra Lite trans gauge and I don't trust what it is telling me. Mind you I have a E99 with NO radiator cooler and the gauge says I am running 125* after running down the highway after 30-40 minutes. But with my infrared thermometer I am 145*-150* and this with outside temps 75*-80*. And I had to buy a new sending unit for the truck and the gauge worked in the motorhome and ran 150*-180*.
I find it hard to believe that it running at 125* and it takes about 15-20 minutes to get up to that.
Now Auto Meter got back to me and gave me this info to check the sending unit. So it either the sending unit or a trans case grounding issue.
Per AutoMeter:<TABLE style="WIDTH: 203.05pt; BORDER-COLLAPSE: collapse" id=yui_3_2_0_1_134546766857837490 class=yiv409369036MsoNormalTable border=0 cellSpacing=0 cellPadding=0 width=271><TBODY id=yui_3_2_0_1_134546766857837489><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 203.05pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=271 colSpan=3 noWrap>2258 sender specifications
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>Celsius
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>Fahrenheit
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>Resistance (in ohms)
</TD></TR></TBODY></TABLE>
38
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>100
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>1123
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>49
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>120
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>708
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>60
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>140
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>460
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>66
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>150
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>374
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>77
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>170
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>253
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>88
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>190
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>175
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>99
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>210
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>123
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>100
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>212
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>119
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>104
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>220
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>105
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>110
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>230
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>89
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>121
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>250
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>65
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>138
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>280
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>42
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>149
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>300
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=144 noWrap>32
</TD></TR><TR style="HEIGHT: 12.75pt" height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>160
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>320
</TD></TR><TR style="HEIGHT: 12.75pt" id=yui_3_2_0_1_134546766857837507 height=17><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 38.9pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=52 noWrap>171
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 55.95pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" height=17 vAlign=bottom width=75 noWrap>340
</TD><TD style="PADDING-BOTTOM: 0in; PADDING-LEFT: 5.4pt; WIDTH: 108.2pt; PADDING-RIGHT: 5.4pt; HEIGHT: 12.75pt; PADDING-TOP: 0in" id=yui_3_2_0_1_134546766857837506 height=17 vAlign=bottom width=144 noWrap>20
#109
Liquid10Rider
08-20-2017 06:05 PM
