cab mount replacement question..
Old Jun 3, 2012 | 10:13 PM
68cabby's Avatar
68cabby
As stated previously..I have already started cutting into the driver side mounts. The way I believe I will do this is to cut out the majority of the whole mount..then possibly leave where the mount welds to the body still intact then I will put the new mount on then weld. Would this be ok to do? I have no other way besides a cutting wheel and I'm afraid ill cut through the floor if I do cut out the flat weld lips.
Old Jun 3, 2012 | 10:19 PM
HIO Silver's Avatar
HIO Silver
Are not the mounts spotwelded to the cab?
Blair Spotweld Cutters
Old Jun 3, 2012 | 10:47 PM
68cabby's Avatar
68cabby
I believe they are but I can't see them! I was going to cut them out but then realized I could jot find the welds? So I thought that if I cut around the weld tabs then the new mounts would fit over. I'm also doing this while the cab is still on the body
Gater180
Apr 17, 2015 04:10 PM
53pickemuptruck
Apr 12, 2007 09:48 AM
1bad71F100
Aug 17, 2005 08:20 AM
dynamic
Sep 22, 2004 10:35 PM
71_4x4_390
Apr 11, 2004 09:49 AM
