Header choice
Old Jun 3, 2012 | 04:05 PM
starkey.monty's Avatar
starkey.monty
Header choice
My current dilemma is finding headers for my 390, on a F250 4SP 4WD, is there anyone who has found a set that fits (exhaust goes passenger side since i have dual tanks)
Old Jun 3, 2012 | 04:11 PM
montana_highboy's Avatar
montana_highboy
F-150-350 4WD 1973-79<?XML:NAMESPACE PREFIX = U1 /><U1:P></U1:P>
Part #9228 - 390/428 engine, 2" primarys, 3 ½" collectors, fenderwell exit.<U1:P></U1:P>
450.00
Catalog
Old Jun 3, 2012 | 04:14 PM
kbrenner536's Avatar
kbrenner536
Depends on your budget. Hedman makes a decent set. But routing is still an issue. Both banks have to go to the passenger side and depending on the size, can make things tight.
Old Jun 3, 2012 | 04:20 PM
starkey.monty
yeah, i just don't want to keep running the log style manifolds, getting past the clutch pedal return spring and assembly will be interesting...
Old Jun 3, 2012 | 04:22 PM
montana_highboy
Don't waste your money on the ill-fitting cheapies that'll rust thru in 3-5yrs.
Yea $200 seems cheaper now, but is it really cheaper in the long run? NO!
Save up if need be, buy once and do it right.
Old Jun 3, 2012 | 04:35 PM
MR-HI-BOY's Avatar
MR-HI-BOY
I went with the hooker headers and i have been pleased but i don't have any gas tanks to deal with.
Old Jun 3, 2012 | 06:25 PM
HIO Silver's Avatar
HIO Silver
Sanderson headers (PN FF427). 'Got them with ceramic thermal coating. Purty, but not cheap.
I opted for these after reading the installation for Flowtechs, Hooker, and Hedman headers where it says to "unbolt the right engine mount and jack up the engine about two inches". Eeeeeek!
Thick 3/8-inch head flanges...
.... and 3/8-inch collector flanges too.
Old Sep 16, 2012 | 11:19 AM
dirtfrmr57's Avatar
dirtfrmr57
HIO, jbhf250 installed the sanderson's and he still needs to pull the headers to change the starter. In you application, can you pull the starter without the headers?
Old Sep 16, 2012 | 11:37 AM
HIO Silver's Avatar
HIO Silver
The issue isn't with getting the starter in or out - there's enough clearance for that. The issue is loosening & tightening the inboard bolt.
Old Sep 17, 2012 | 08:01 AM
dirtfrmr57's Avatar
dirtfrmr57
I am not familiar with "inboard bolt" terminology. Is that the bolt on the top side of the starter that is already difficult to reach?
Old Jun 9, 2013 | 12:47 AM
dirtfrmr57's Avatar
dirtfrmr57
Well, I splurged on the Sanderson headers for my 390 build in my '76 4X4. They sound great. But it is absolutely, 100% impossible to change the standard starter without removing the header. My mechanic couldn't do it while the engine was on the cherry picker before the install. And I couldn't do it when I lost the starter, this past weekend. That was one of the main reasons I spent $600 rather than $200. Live and learn. I will enjoy them. This is the way a pickup is supposed to sound. And towing is a joy.
FossenRacing
21
Mar 29, 2013 11:42 AM
whiteisright
May 17, 2012 10:31 AM
Grubbworm
Apr 21, 2011 09:56 PM
Grubbworm
Apr 21, 2011 12:35 PM
pullinair
Maryland Chapter
May 12, 2007 05:24 AM
