Modular V10 (6.8l)
Looking for upgrades
Old Jun 2, 2012 | 10:03 PM
tmoade's Avatar
tmoade
Looking to see what folks are using for cold air intake and exhaust. I want more power and hopefully some fuel savings. Also looking into installing a SCT tuner any input?
Old Jun 2, 2012 | 11:55 PM
jh818's Avatar
jh818
Get the Y pipe and tuner. Mike at 5 Star should be able to help you and understand it better.
Old Jun 3, 2012 | 08:58 AM
scraprat's Avatar
scraprat
Top Answer: 5
"I want more power and hopefully some fuel savings."
I believe the Y pipe helped the pre '05' 2v V10s the 3v V10 are pretty good from the factory but if I'm wrong someone will correct me.
With power comes fuel consumption and a BSEG. You have an '09' and if you read more of these threads these 3v v10s breath pretty good already. Try a 5 star X3 tunes that will wake your truck up, firm the shifting and get rid of the throttle lag and you wont suffer mileage drop and possible get a little bit better as long as you keep your foot out of it which can be tough to do.
http://5startuning.com/v10/index.html
On that page the 2 clips are from my truck and that is just with the 87 tow/ performance tune which is all I have run on the truck. I tried the economy tune and it did nothing for me, I have the 89 tow/ Performance tune which I have not used yet because the 87 does just fine and has plenty of spunk when needed. Other guys have used the higher octane tune and enjoy them and have gotten better MPG but you'll pay more at the pump.
Old Jun 3, 2012 | 07:59 PM
mikeismadness's Avatar
mikeismadness
Replacing the muffler or doing a cat back is practically a modification for sound
Old Jun 4, 2012 | 09:12 PM
tmoade's Avatar
tmoade
Thanks for the feedback looks like a phone call to Mike at 5 Star is the next step.
Old Jun 4, 2012 | 10:15 PM
Quad Racer's Avatar
Quad Racer
Yup. 5 star will take great care of you. It's pretty amazing the performance difference. Towing, not sure with the tune I'm currently running. Its an 87 octane performance tune so I may need to get the 87 tow tune before the next Ohio truck meet.
Old Jun 4, 2012 | 11:00 PM
Aune163rd's Avatar
Aune163rd
Whats the tune do for it exactly? How does modifying shift points and thigns like that change your MPGs?
Old Jun 5, 2012 | 01:46 AM
mikeismadness
Basically the tune makes yor vehicle use every drop of gas that is dropped into the combustion chamber. The timing and all that good stuff is more fine tuned than the factory
Old Jun 5, 2012 | 02:35 AM
Fosters's Avatar
Fosters
To be honest, I was underimpressed with the power gains when I first put on the tuner, I thought maybe this board built up the 5star tunes a little too much. I did like the transmission programming, and with it, shifts were exactly when you expected them to be. No more going uphill, downshifting, then going downhill and forgetting to upshift. A lot less gear hunting, a lot more using the engine's torque to move the truck.
Then before I sold my excursion, I removed the tune and drove it stock for the last week before I sold it. Holy smokes did I feel the power difference then!
A very worthwhile mod, the transmission shift points alone are worth it.
Old Jun 5, 2012 | 03:44 AM
18436572's Avatar
18436572
I did just about every modification possible (aside from forced induction) with little to no gains. I had the following modifications,
Doug Thorley long tube headers, high flow cat, flow master exhaust, 4.56 gears, tuner, cai, experimented with egr cycling among other things.... Was still unimpressed. (of course I had the 275 hp V10 in my truck).
Old Jun 5, 2012 | 02:30 PM
cbzdel's Avatar
cbzdel
my mods:
5 star tuner
air aid intake
flowmaster exhaust
next: gears
As it sits right not, I have more power than I know what to do with
Old Jun 5, 2012 | 03:30 PM
Fosters's Avatar
Fosters
Time for a pi headswap.
Old Jun 5, 2012 | 10:15 PM
Quad Racer's Avatar
Quad Racer
You werent impressed with the gear swap? That seems to be the easiest way to gain real power at the wheels. Gears make all the difference in the world IMO.
Dave0629
Modular V10 (6.8l)
Oct 24, 2012 11:09 PM
mathlex
Nov 30, 2011 01:18 AM
Caropan F150
2004 - 2008 F150
Sep 22, 2009 05:33 AM
Quill Gordon
Sep 9, 2009 04:48 PM
Bennyboy2002
Computer Chips & Tuners
Mar 3, 2006 08:03 AM
