squeak squeak
Old May 30, 2012 | 12:45 PM
Justin03PSD's Avatar
Justin03PSD
squeak squeak
I heard something new today with the windows down.
It starts around 15 mph and gets faster with speed. It is not engine RPM dependent.
Sounds like it's coming from the passenger front. Around 45 mph the period of the squeak is about 1 per second.
I have read posts about pulling the ABS sensor and greasing the unit bearings. Any other ideas?
Old May 30, 2012 | 01:46 PM
Bonanza35's Avatar
Bonanza35
If you think its a bearing, I'd pull the wheel and check. Probably to late at this point to just lube.
Chet
Old May 30, 2012 | 04:54 PM
camodown's Avatar
camodown
Had a bad u joint that squeeked once. Mught be time to check those!
Old Jun 2, 2012 | 10:16 AM
Justin03PSD
I am hoping it's just something I can grease up. We've had a lot of rain recently and I drove on a couple roads that were washed over. I noticed it shortly after that.
The thing that gets me is how slow the squeak is compared to how fast I'm driving. It changes with speed but seems like it's "geared down", if that makes sense.
I'm quickly approaching 60k, with a lot of maintenance and upgrades planned. I'm going to follow guzzle's pages on the hubs and needle bearings but wanted to know what else I can look at doing.
Old Jun 2, 2012 | 11:30 AM
carltonwebb's Avatar
carltonwebb
check front brake pads.
Old Jun 2, 2012 | 12:55 PM
amthatiam's Avatar
amthatiam
My truck did the same thing, got worse over time drove me nuts. Turned out to be the nylon spacers in the springs were toast. Replaced them and no more squeeks. They are white and easy to replace with a pry bar.
Dan
Jeepzor
Jan 5, 2016 05:34 AM
mtpiper
Jun 22, 2015 12:35 PM
hammer65
Jan 5, 2011 04:23 PM
JIMRSX
Apr 27, 2010 07:25 AM
drillerdan
Nov 21, 2004 06:28 PM
