upper oil resivour leaking down....
Old Jun 3, 2012 | 12:42 PM
fordman67's Avatar
fordman67
So the oil cooler assy has to come off to access the other lower one? The upper is accessed from inside resivour?
behind timing gear cover? Behind hpop? I have been looking for parts brake down but have been unsuccessful in my quest....
Old Jun 3, 2012 | 01:09 PM
fordpride's Avatar
fordpride
This is for 96-97 psd 94.5-95 is built into the front cover
This is the one by the HPOP
Parts 3 4 5 6
Old Jun 3, 2012 | 01:17 PM
fordpride's Avatar
fordpride
This is the one in the you can see with filter removed.
This one is missing (round hole)
Thin one is in place
The other I think you have to remove the oil cooler to see it
Old Jun 3, 2012 | 09:17 PM
oldbird1965's Avatar
oldbird1965
When I did my oil cooler there was a spring-plunger thing in the filter head. I'm thinking that's it.
The other one in your diagram you put up, don't they call that the anti-siphon value? This has always confused me because Bob at dieselsite when he sent me the adrenaline sent me the wrong gasket and mine keep leaking down. Why would mine leak down just because of the wrong gasket if I have a 96 with the value?
Old Jun 3, 2012 | 09:27 PM
fordpride's Avatar
fordpride
Not sure in the gasket. But the one in the block if the spring breaks it will leak down as it stays closed when the tuck it turned off and when started the oil pressure pushes it open
Old Jun 3, 2012 | 10:17 PM
fordman67's Avatar
fordman67
Was it leaking down internally or externally? I am almost clean enough in my garage to get my truck in.hopefully tomorrow night will be the finish....then to fix a laundry list of things and level the old gal up...
Old Jun 3, 2012 | 10:23 PM
DRRXR's Avatar
DRRXR
Talking
That pic sure looks familar lol.
Heres the block
Old Jun 3, 2012 | 10:48 PM
oldbird1965
Internally, good luck with the laundry list!
Old Jun 4, 2012 | 01:14 PM
Action4478's Avatar
Action4478
This is a pic of the second valve in the header , The header has to be removed to service it .. You can see it under the oil filter if removed , it is in the other rectangle shaped hole ...Name:  2nd bypass valve.jpg
Old Jun 4, 2012 | 08:53 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
a couple of other views:
Old Jun 4, 2012 | 09:11 PM
fordman67's Avatar
fordman67
Thankyou fellas so much.i got the shop cleaned out.i will be diving into all my repairs tomorrow.i guess i need to order the reseal kit for the oil cooler.i will have the coolant out anyway to repair the radiator nipple being broke off and poorly glued on.i will report back on this problem soon i hope
Old Jun 4, 2012 | 09:18 PM
ReBilld's Avatar
ReBilld
Good luck bud! I hope it all goes smooth for ya
Old Jun 4, 2012 | 09:24 PM
  #28
oldbird1965
x2^^^^^^^^
Old Jun 5, 2012 | 04:52 AM
  #29
DRRXR's Avatar
DRRXR
3xxxxyyyyyzzzzz
Old Jun 5, 2012 | 08:47 AM
  #30
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Originally Posted by DRRXR
3xxxxyyyyyzzzzz
XXX (3X ???) LOL.
X4
