Sponsored by: Real Truck
F 250 problems
Old Jun 1, 2012 | 08:27 PM
roger.lees51's Avatar
roger.lees51
F 250 problems
Hello,
I have a 2001 F 250 that had a high speed miss and now it's developed into a low speed miss and stalling at idle.
I ran the auto engineering scan tool and came up with the following error codes-
P1280 injector control pressure sensor circuit low
P1670 electronic feed back signal not detected
C1701 left rear sensor circuit fault
P1867 transfer case 2 wheel drive solenoid circuit failure
Can anyone help with with what/ where I need to go to get this fixed?
Thanks,
Roger
Old Jun 1, 2012 | 10:31 PM
DIXIEDOG1's Avatar
DIXIEDOG1
I got nothing but you might get more feedback if you post it in the Super Duty forum section instead of the F150 section
https://www.ford-trucks.com/forums/f...orums/forum30/
You could post it in the forum for the engine you have also if that doesn't work.
Old Jun 2, 2012 | 07:02 PM
roger.lees51
Thanks, I did not realize there were different areas to post messages.
Old Jun 3, 2012 | 11:10 AM
sspikaroo's Avatar
sspikaroo
GEEZ! Did all those codes come in at the same time? Maybe something happened to a wiring harness? Sorry to hear of your troubles.
Old Jun 3, 2012 | 02:03 PM
roger.lees51
well, i guess they came in at one time. I'm not even sure what i am seeing is the correct page for the error codes.
I did check the ICP again by unplugging it, etc and all seems fine. However, I cannot fined where to run the check for the CPS. I have a list of sensors to pick from and it is not on there.
This high tec auto world it tough on someone's whose first hot-rod at 16 years old was a 1949 Oldsmobile.
nv2713f250
May 2, 2016 12:10 PM
magum350
6.4L Power Stroke Diesel
Dec 22, 2012 11:00 AM
roger.lees51
25
Jun 24, 2012 09:18 AM
roger.lees51
Jun 2, 2012 08:00 AM
fixnair
Mar 12, 2011 07:21 PM
