AGHHHHH!!!
Old Jun 1, 2012 | 10:41 PM
roger.lees51's Avatar
roger.lees51
AGHHHHH!!!
Hi,
I have a 2001 F-250 that had a high speed miss that is now a low and high speed miss and it stalls at idle.
I ran the scan tool as best I could and came up with these error codes-
P1280 injector control pressure sensor circuit low
P1670 electronic feed back signal not detected
C1701 left rear sensor circuit fault
P1867 transfer case 2 wheel drive solenoid circuit failure.
Can anyone]e out there give me some ideas of where to go from here?
Thanks,
Roger
Old Jun 2, 2012 | 04:18 AM
helihansen's Avatar
helihansen
Im no expert but have had similiar issues, You can unplug your ICP until you get a new one. I found the best price at Ford Parts - Tousley Ford Parts Depot
Old Jun 2, 2012 | 08:00 AM
4EXTRDR's Avatar
4EXTRDR
Your symptoms describe a CPS going out...does it start right up when it stalls at idle? I would toss a new CPS in it first, may cure all your problems.
bwpatton1
Jul 9, 2015 08:41 PM
JOHN2001
22
Jun 1, 2014 11:54 AM
grec-o-face
17
Jan 15, 2014 10:09 PM
grantorino
Feb 9, 2009 02:46 AM
jnye6625
20
Mar 7, 2007 02:51 PM
