ARP head studs
Old Jun 1, 2012 | 01:13 PM
Regulator1988's Avatar
Regulator1988
ARP head studs
Cab on what are the tricks, tips, and which bolt is the most PITA?
Old Jun 1, 2012 | 01:25 PM
Getsome68's Avatar
Getsome68
Your welcome:
https://www.ford-trucks.com/forums/8...-hvac-box.html
Old Jun 1, 2012 | 04:01 PM
Regulator1988
Originally Posted by Getsome68
I really don't want to do that
Old Jun 1, 2012 | 04:50 PM
Regulator1988
No easier way?
Old Jun 1, 2012 | 04:59 PM
snorindad's Avatar
snorindad
Get an overhead creeper it make all the difference in the world. I borrowed one and did my heads last summer. Did not seem as bad as some make it out to be. On the other hand it is not the simplest job to do either. I did remove half the hvac box. And I have a break down cherry picker to lift the heads W/exhaust manifolds on and also installed the heads with the exhaust manifolds on. You will also need a 250# torque wrench. I did it over a two week span and took my time to make sure it was a onetime deal. This forum is your best resource and the people on here are very helpfull and full of knowledge.
Old Jun 1, 2012 | 05:04 PM
snorindad's Avatar
snorindad
A good set of wrenches and sockets with a variety of extensions and sizes, 1/4, 3/8 1/2 inch with universals will make it easier also.
Old Jun 1, 2012 | 05:19 PM
Regulator1988
How do you get get the passenger side?
Old Jun 1, 2012 | 05:25 PM
snorindad's Avatar
snorindad
I pulled half the hvac cover and the wheel well insert out and was able to get to everything just fine on the passanger side.
Old Jun 1, 2012 | 05:29 PM
Regulator1988
Im sorry im new to this truck what is the hvac?
Old Jun 1, 2012 | 05:40 PM
snorindad's Avatar
snorindad
Heating, ventilation, air conditioning (HVAC). On the passenger side in the back there is a black plastic cover over the evaporator and it splits in two. If you remove the outer half you can get to the valve cover and head bolts easier.
Old Jun 1, 2012 | 05:43 PM
Regulator1988
it is easier to remove
Old Jun 1, 2012 | 06:27 PM
snorindad's Avatar
snorindad
yes I would remove it to do the heads
Old Jun 1, 2012 | 06:30 PM
Regulator1988
The passenger side it easy?
Old Jun 1, 2012 | 07:30 PM
cheezit's Avatar
cheezit
the procedure is in the shop manuel to remove the heads. ford does not pay to remove a cab on a 6.0 for anything.
Old Jun 1, 2012 | 07:38 PM
Regulator1988
I'm replacing the studs one by one
Mike in Arizona
May 3, 2018 12:46 AM
shift6durastroke
Dec 27, 2009 09:51 PM
96_4wdr
Aerostar
Oct 14, 2007 08:21 PM
Pustman
Aug 11, 2006 12:44 PM
